08-05-2021
06:36
06:43
WilsonFitbit
08-05-2021
06:36
06:43
WilsonFitbit
Cannot see my current activity., My dashboard will not not sync. What is happening????? I would like to see how I am doing ? Help
08-05-2021 06:48
08-05-2021 06:48
Hello @BJTremblay. Welcome to the community forums.
Thank you for the detailed information. At this time, I'm not sure about what could have caused this inconvenience, but I'd like to let you know that the syncing process can be affected by several factors. For a list of troubleshooting steps, I'd recommend visiting this help article: Why won't my Fitbit device sync?
On a side note, please make sure you have a Charge 3. If in case you haven't paired your Charge 3, you can set up your tracker by following the steps here: How do I set up my Fitbit device?
Hope this helps.
08-05-2021
11:31
15:00
AndreaFitbit
08-05-2021
11:31
15:00
AndreaFitbit
hi, I am about before, Imust of hit the wrong button.I have a Charge 2, .Hopefully I can fix the problem about it not syncing as someone told me before.Thank you for your info.Gonna try & get it to work.Funny how I can see messages, but cannot see my stats
Moderator edit: format.
Best Answer08-07-2021 06:05
08-07-2021 06:05
@BJTremblay Thank you for your reply.
We appreciate this information and thanks for letting us know that you will follow the suggested tips. I hope you can get back on track soon.
See you around.
