10-23-2018
08:29
15:03
10-23-2018
08:29
15:03
I purchased the Charge 3 last week. I The first 2 days it worked fine. Now everyday it locks up and when you press the side button, nothing happens. The screen just stays blank. The green pulsometer light on the back side is continuously flashing but that is the only thing that indicates the device is working. It also will not sync with my iphone 6s when this happens. I have to take off the watch and put it in the charger, hold the button for 8 seconds to restart it. after that it works fine. This is crazy, I have to do this everyday. What is going on? Is my device defective? I do have the latest update on the Charge 3 so I know that is not adding to the issue. Can anyone help me to figure out if this is a piece a crap and I need to request a replacement or is there something going on that is easily fixed? How do i get a working device this is really frustrating.
10-25-2018 07:04
10-25-2018 07:04
Welcome on board @Sjahan! Sorry to hear that your Charge 3 is not syncing properly. Thanks for already troubleshooting this inconvenience, nice way to go!
Since you've exhausted all the tips and recommendations for this situation, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
Best Answer10-25-2018 07:17 - edited 10-25-2018 07:18
This isnt a case for somebody from support to touch base and try to assist... The Charge 3 is riddled with Software bugs that simply shouldn't have still been present at consumer release. These issues are effecting hundreds/thousands of early adopters and there seems to be nothing being done by Fitbit to quickly address these problems and fire out firmware releases to fix them. Ive had Fitbits before, but never have i experienced the widespread issues the charge 3 seems to be bringing us. Its a real shame because the unit is great... if it works as it should.
10-30-2018 13:02
10-30-2018 13:02
Hello,
No one has reached out to me yet with a resolution. The problems continues, it is working sporadically, it does not start when left idle for a long period time (over night or more than 7/8 hours).
I want to send it back and get a replacement device that actually works.
Thank you.
Best Answer01-26-2020 20:33
01-26-2020 20:33
I’m having to reboot my charge 3 everyday
Problems need fixing are
sometimes won’t sync
sometimes no device found
sometimes no sleep tracking
sometimes not recording water intake
doesn’t count steps when walking in water
sometimes doesn’t record day of activity
this is driving me mad
don’t know if only my one or others experiencing too ?
should I take it back to where I brought it and get a refund ?
Best Answer06-23-2020 08:52
06-23-2020 08:52
Can you enter a ticket for me? It was fine for months but now it's barely working. What should i do?
Thanks.
Best Answer06-23-2020 20:47
06-23-2020 20:47
