10-31-2020 12:53 - last edited on 11-01-2020 11:45 by LiliyaFitbit
I have several straps for my fitbit which I bought a year and a half ago. And I am having issues changing g straps. None of the are attaching on the top. The bottom works fine but the top doesn't. I can't even get the strap I just took off to attach. Please advise. And yes I tried moving it back and forth and up and down.
Thank you!
11-02-2020 15:54
11-02-2020 15:54
I take off my bands once a week, clean them and rotate them.
Today I had trouble getting one side to clip on.
What worked, is I used my finger nail and pressed repeatly on the little ‘clasps’ that the band connects with on the pebble itself. They were in the ‘down’ position so the band wasn’t catching.
Hope that helps you.
11-01-2020 11:44
11-01-2020 11:44
Hi @4UHRM, it's nice to see you again in our Community Forums.
I am sorry to hear about the difficulty you're experiencing with attaching your Charge 3 straps. Thanks for trying to resolve this, I appreciate the additional details and I am here to help. Before considering other options, I recommend confirming the steps to attach a band at How do I change the band on my Fitbit device?
Let me know how it goes.
11-01-2020 12:33
11-01-2020 12:33
11-02-2020 14:55
11-02-2020 14:55
Thank you for your reply, @4UHRM.
I appreciate your efforts and the additional details. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Let me know if you have any questions.
11-02-2020 15:13
11-02-2020 15:13
11-02-2020 15:15
11-02-2020 15:15
Thank you so much I appreciate your assistance. Take care
Heather
11-02-2020 15:54
11-02-2020 15:54
11-02-2020 16:07
11-02-2020 16:07
Thank you that seems to have worked with one strap. I used tweezers as I don't have nails that are long enough. I will give my watch a clean in that area before I try again. Thanks sooooo much I really appreciate it.
11-02-2020 16:27
11-02-2020 16:27
Hi @fritzmom, it's nice to see you again in our Community Forums. Thank you for your reply, @4UHRM.
@fritzmom Thank you for sharing your experience and solution. I appreciate your time and efforts to help other users!
@4UHRM I appreciate your feedback and hope the tips shared by @fritzmom will be helpful.
I'll be around if you have any questions.
11-02-2020 16:48
11-02-2020 16:48
You’re very welcome. Glad I could help!
11-08-2020 01:32
11-08-2020 01:32
I'M having the same problem today 😔.
What should I do?
11-08-2020 11:18
11-08-2020 11:18
The problem was the latch on the back of the "watch" was stuck in the down position. I used a pair if tweezers (lightly) underneath the latch to lift it back up. That worked for me. Another user is just used their nail. And that worked for them. Hope it helps!
The latch is the button you press to remove the strap.
