08-28-2020
11:35
11:22
08-28-2020
11:35
11:22
Hi. I've had my fit bit charge 3 for a couple of weeks. It's just started to randomly go to a screen displaying 100 and a twinkling diamond logo. It stays on it like it's frozen. I hold down the button on the side to reset it and then it's OK. It then does this again repeatedly.
06-11-2021 05:58
06-11-2021 05:58
Hello everyone. @Psanchezz Welcome to the community forums.
If you've tried the basic restart and that didn't work, I recommend performing a long restart. A long restart is different than the basic one and you can complete the process by following the instructions below:
If that doesn't work, I recommend contacting our Support Team for further assistance. Note that you can contact them through chat or over the phone but Phone wait times are longer than normal and I recommend initiating a chat.
See you around.
08-28-2020 17:37
08-28-2020 17:37
I have the same problem, too: Charge 3 with the 100 and blinking logo -frozen. Just did an update to my Charge 3 earlier this week... I wonder if the update had a bug/glitch..?
08-28-2020 21:27
08-28-2020 21:27
09-04-2020 17:31
09-04-2020 17:31
Yes, my screen is stuck with 100 and a "twinkly diamond" frozen on the screen as well. The system did an auto software upgrade earlier in the week and shortly after that the device started "twitching". It buzzed fir a few seconds at a time periodically throughout the day. Not like a quick buzz when I hit a goal, but blinking and buzzing for a while. When I hold the side button to turn it off, nothing happens and the device stays on and the screen is frozen. It is as though the side button is not responsive. Please help me
09-04-2020 17:32
09-04-2020 17:32
This is happening to Me too.
09-08-2020 05:18
09-08-2020 05:18
This happened to me too. Does anyone have a fix?
09-09-2020 08:25
09-09-2020 08:25
would love to see a fix too! upgraded a couple weeks ago...
09-09-2020
11:17
09:15
AndreaFitbit
09-09-2020
11:17
09:15
AndreaFitbit
I called the help line yesterday and they said to fully delete the app from
my phone and then reinstall it. I am afraid I will loose all my data, and
haven't done it yet since I don't have the time. However, I really have
nothing to loose if I can't access my tracker anyway. I'll keep the group
posted on any progress I get.
Moderator edit: format.
09-15-2020 10:45
09-15-2020 10:45
Please let us know... its now doing this daily and 2x a day...
09-19-2020 10:03
09-19-2020 10:03
Same Problem for me...
Twinkling diamond logo with 100 underneath.
I’ve deleted and re-installed app.
Connected to the charger, held on for 15 seconds. Screen went blank and now will not start or show any screen image but it still vibrates when the side button is pressed.
Please advise
09-20-2020 08:13
09-20-2020 08:13
09-28-2020
14:21
09:16
AndreaFitbit
09-28-2020
14:21
09:16
AndreaFitbit
ok... knock on wood.... no error in the last week...😃 ...
Update: it is still happening occasionally. So today, Oct 9th 2020, the display is dimming, most likely from the largely lighted diamond 100 glowing until the battery runs out... I like the fitbit, but seriously thinking if I want to send another $150 to get the charge 4 and only last 1 yr. Very disappointed in the product.
10-09-2020 09:11
10-09-2020 09:11
has it been fixed? or did fitbit replace?
10-17-2020
23:41
09:17
AndreaFitbit
10-17-2020
23:41
09:17
AndreaFitbit
Follow-up. I did uninstall and reinstall the app from my phone, as recommended by the help desk guy. It did not ot help.
I did the plug in, hold button for 15 sec, unplug, etc. It did temporarily get rid of the 100 screen, but then the screen was just blank. Now 20 min later, it's back tut o tut he 100 screen with the diamond.
I have been unable to use my fitbit charge 3 for 2 months now- Very disappointing!
10-30-2020 14:31
10-30-2020 14:31
Same thing, Charge 3, update, twitched/flickered, then 100 and a diamond. I reinstalled the app, put it on the charger and held the button. Now it is completely bricked. I have not seen a response from Fitbit on this yet.
06-10-2021 15:43
06-10-2021 15:43
Mine did it this morning, I hope there’s a solution because I like this one
06-11-2021 05:58
06-11-2021 05:58
See you around.
06-15-2021
04:18
06:14
WilsonFitbit
06-15-2021
04:18
06:14
WilsonFitbit
me too I'm about to stop using mine.
Moderator edit: word choice
06-17-2021 06:16
06-17-2021 06:16
Hello @Stentaford. Welcome to the community forums.
I'm sorry for the experience. I was able to see that you reached out to our Support Team and they have provided information and assistance. If you still have questions or inquiries about the outcome of your case, I recommend replying back to them and they will be glad to continue assisting you.
See you around.
09-07-2022 13:49
09-07-2022 13:49
Mine too ,and i cant remove it, i have followed all the instructions, but nothing works. Waste of money
