02-28-2019
12:55
05:03
JuanJoFitbit
02-28-2019
12:55
05:03
JuanJoFitbit
Agree. Takes forever to sync. Now my doesn't get my text. I know, restart...blah blah, very disappointed.
Hi @barbie2584, Welcome aboard! I hope you're doing well, I moved your post to Charge 3 boards as you have a more specific question.
I'm sorry to hear that the synchronization of your Charge 3 it's not easy to accomplish. I recommend you to check all the requirements listed in this article: Why won't my Fitbit device sync?
If all those requirements are in order, you can try removing the tracker from your phone's Bluetooth settings with all devices listed there too. Restart your phone and your tracker. Now add the tracker to the Bluetooth list and reopen the app to start a sync.
Finally, if those steps don't help I would like to know what phone are you using to try to synchronize. This to check the compatibility with the Fitbit app.
Hope that helps, let me know how it goes!![]()
Thank you very much for your response @barbie2584.
I can confirm your device it's compatible with our app. If you haven't already done so I would like to suggest you to check the following requirements :
If your apps update automatically, check the Recently updated or Up to date list to see if the Fitbit app was updated.
Hope that helps, let me know how it goes. Have a nice weekend! ![]()
Best AnswerYeah, I totally agree. I just got the charge 3 and it is constantly having issues, including the sync. I have it on all day sync and it won't. I have to manually open the app and drag it down to work. Even then, if it does sync it takes forever, or it says tracker not found. I have repeatedly rebooted my phone, and the tracker, along with updating the app and it keeps happening. My heart rate chart is also not working. It stopped after tuesday. It shows my sleep and resting heart rate, but won't show my cardio and exercise heart rates and zones, which is annoying as I really like seeing my progression when I work out. I didn't have any of these issues with the charge 2. I'm regretting the "upgrade".
Thank you for your reply @barbie2584 and @ANTIGONEELECTRA.
@barbie2584, can you please provide more details? Have you checked the requirements listed in my previous post?
@ANTIGONEELECTRA, I'm sorry to hear that you're having difficulties to sync your Charge 3. Thanks for trying the troubleshoot. You can also try removing the tracker from your phone's Bluetooth settings with all devices listed there too. Restart your phone and your tracker. Now add the tracker to the Bluetooth list and reopen the app to start a sync.
If those steps don't help, I would like to know what phone are you using to try to synchronize. This to check the compatibility with the Fitbit app. You can get more information about compatible devices in this page.
01:37
10:44
GraceGFitbit
03-13-2019
01:37
10:44
GraceGFitbit
In the same boat as you...Got mine today and it's giving me the biggest headache....
I'm on Android, it's like Fitbit doesn't give a **ahem** about Android..
Not sure what your return policy is but I'm considering returning it over the weekend...so disappointing, come on Fitbit it's 2019 lol
03-13-2019
16:19
10:36
GraceGFitbit
03-13-2019
16:19
10:36
GraceGFitbit
I actually have a Samsung and my previous Charge 2 never had a problem with it. I think it's the new Charge 3.
Update
Hi,
I have a compatible phone, Samsung S8+. I never had a problem with the Charge 2. I have again just deleted and reinstalled the app, restarted my phone, unpaired the Bluetooth and paired again, as well, as the tracker. I can have my phone on me all day and even though it is set to all day sync, it won't. It will only sync once I have opened the app and let it sit for a minute to do it. I also know it is catching my heart rate, yet it won't display it on the apps heart rate chart (since March 5) either as a resting heart rate (on top of the page) over time or as a function of daily exercise (below per day). It also states 0 of 5 days of exercise goals this week even though I have done the same amount of exercise as previously. I am hazarding a guess the information is simply not transferring over to the app.
Thank you for getting back to us @ANTIGONEELECTRA and @Dfresh13.
If your device still won't sync, you can try these:
@Dfresh13, if that didn't help I would like to know exactly what Samsung phone are you using to try the synchronization? To know more about our warranty policy click here.
I hope this can be helpful, give it a try and keep me posted. Have a nice weekend!
Best AnswerYou could look at your phones battery settings. Android use aggressive battery optimisation. This worked for me on huewai p20 https://youtu.be/a91CDZh3LlQ
AAnd this video https://youtu.be/Z0iqx-l3cMg
This problem is not solved. The responses don’t even address my real problem. My problem is the charge 3 sync time varies widely from 30 seconds to 5 minutes. If I pair a charge 2 to the same phone, it consistently sync in 30 seconds. Wake up fitbit, there is a problem with the charge 3. Unless this can be fixed with a firmware update, I have purchased my last fitbit product.
Ken
I have an iPhone max plus and have the same issues.
I tried all the trouble shooting and nothing seems to work.
This wearable device does not sync within the expected time frame, It requires being on a network, won't sync with cellular data and might take up to 10" for one or two days of data. The texts are received on the Charge 3 very inconsistently so I am considering pitching for an Apple Watch. I have a heart rate issue and hoped to be able to monitor but now am skeptical of data. My friend with an earlier Fitbit registers 2000 steps more than I on the same hike. This is another reason I am dubious there is value in the product. I have tried all the fixes but the problem just recurs.
This is very true, the sync is very slow. There was no problem like that with Fitbit Charge 2. I blame poor software design. It is either software on the device itself or the IOS software (not sure if this problem affects iPhones) The amount of data needing transfer is not significant and as I can see - many people are affected. I find this frustrating that with such a a huge impact on the community the issue still hasn't been addressed properly and the software developers still did not find the fix (or not worked on it at all which would not surprise me).
Worth considering moving to another fitness watch vendor if all Fitbit moderators can do is to point us to the useless troubleshooting steps and turn off/on solutions. This is obviously not a problem with the end user set-up and calling this thread "Solved" only shows the lack of professional attitude and support at Fitbit.. Big shame after really good start with previous models..
I totally agree. I will not be purchasing Fitbit products in the future. Responses provided by Fitbit are basically unresponsive to the real issue. The issue is that they seem to be the only ones who can’t make Bluetooth work properly. I have many devices that use Bluetooth and only Fitbit has problems
Best Answer is fine for those who cannot synchronise, but it doesn't help those of us for whom the synchronise (in my case a Charge3) is extremely slow; plus, it sometimes waits all day to synchronise, with no updates of steps during the day (wifi and Blue tooth are switched on). For example, I went to the gym yesterday about 3pm and ran 6k; later that evening, I checked my phone app (I had the phone with me in the gym, incidentally) to see what my steps total was. It was still showing the 160 steps from when i checked first thing that morning. It took about 20 minutes to synchronise to show my steps total for the day (18k). With my last Fitbit, the Alta, the steps updates were pretty much instant, as was the sleep breakdown; and I thought the Charge3 was an upgrade! I get that Charge3 is synchronising more info than the Alta, but often the wait time is ridiculous. It takes about 10 minutes to show my sleep breakdown first thing in the morning.
I do not agree that this problem is solved. I am on Charge 3, and it takes forever to sync. The heart rate is the slowest. No matter how much I pull the app to sync, the heart rate wont get updated. It will only sync the next day. I am on Note 10 and I dont think this is a device issue. Been like this ever since I changed to Charge 3. Are they any fixes from fitbit in the pipeline ? Am rethinking my options now.
