10-11-2018
07:46
15:06
10-11-2018
07:46
15:06
So I got mine a couple days ago but the touchscreen does not seem to be working. I tried swiping every which way and restarting the device multiple times but still nothing. I even had someone else try it in the event I was doing something incorrectly but still nothing. Tapping on the screen does nothing either. Anyone else having issues with it?
12-18-2018
10:18
10:35
12-18-2018
10:18
10:35
I was having the same problem. My touchscreen was not working and following the restart protocols also did not work. So I switched the clock face through the mobile app and everything worked fine again. I hope it helps!!!
Moderator edit: format
12-18-2018 11:07
12-18-2018 11:07
Thanks for getting back @PauloPeres, @Mufario, @HotDaddy84! I'm glad to hear that your Charge 3 is back on track, thanks for sharing the outcome! ![]()
Hi @LaffyFBuser! I totally understand where your concern is coming from. If the restart has partially worked for you, can you please try switching to a different clock face to see if that works?
Looking forward to your reply!
Best Answer12-18-2018 13:59
12-18-2018 13:59
Best Answer12-25-2018 09:41
12-25-2018 09:41
Hello,
I was given a Charge 3 for Christmas, and I'm having the exact same issues .For the longest times, I could not even update the settings has my phone said it didn't have internet connection. I was finally able to switch the clock face, but the screen is still frozen with no swipe functionality working.
I have placed it on the charger and attempted to reset multiple times, but it is already fully charged. Also, every time it resets the 🙂 appears instead of black screen.
Also, it is long over 400 steps this morning as I just sat on the couch wearing it trying to troubleshoot it. like other users have stated, this is not going to be helpful data if it is going to constantly add steps without any actual activity.
please assist in helping fix this issue as I would love to use this new present!
Thanks,
Jay
Best Answer12-28-2018 14:29
12-28-2018 14:29
I am having the same issue. Have had the tracker for almost three days now and has been working fine up until this morning when I suddenly cannot use the touchscreen. Swipe it any which way it does nothing. Screen still turns on but that's about it. It still gets notifications but can't really view then since screen is unresponsive. Aide button still works and that's about all I can use to do anything with the screen.
Have already tried the following suggestions with no luck:
-Restart device (screen goes black and comes up with smiley face)
- Turn off blue tooth in phone so device is not syncing and then restart
- Change the click face in the app
Have tried all of the above a few times and still nothing.
What's next? I'm beginning to think it might be faulty 😞
Best Answer12-28-2018 18:06
12-28-2018 18:06
For this issue, it’s very common with the charge 3’s. Usually restarting the device works for a while, until it happens again. And again. And again. Fitbit knows about this (they have a sticky thread where they have said they recognize the issue) but there has been no update. This issue has been happening since October, and Fitbit usually decides to send you a replacement after failed inquiries. The issue is that the replacements also have a chance of this issue. I’ve had 3 of the trackers and all 3 had this issue. My advice is to return it and move on to another device or even another company such as Garmin. The charge 3’s work well for some, but for others it’s just a paperweight that doesn’t respond on the display.
Best Answer12-28-2018 22:35
12-28-2018 22:35
Best Answer01-06-2019 07:30
01-06-2019 07:30
I have had my Fitbit Charge 3 since 01/05/2018 at 7:03 pm Arizona time. It is now 8:24 am and have the exact same problem. I visitied the message board here and did the 8 second and 15 second "rest" with zero success. I then called the customer service number. I spoke with someone who suggested I do the exact same thing I just did with again zero success. Very frustrating for a product that is 13 hours and 21 minutes old. Customer service want to put in a "work order" and I would get an email in the bext 2 to 3 days!?!?!? Concerning my problem with my brand new Fitbit Charge 3??? I told him I would be returning to Macy's to simply exchange it. Not a good start with a brand spanking new customer to your Fitbit community.
Best Answer01-06-2019 07:49
01-06-2019 07:49
I am having the same problem with my touchscreen. It was working fine an hour ago (and had been since the end of November) but then just stopped responding. It was over 80% charged earlier this morning. Doing resets caused buzzing but nothing else. Thanks.
01-06-2019 09:43
01-06-2019 09:43
01-06-2019 09:47
01-06-2019 09:47
01-06-2019 12:14
01-06-2019 12:14
My Charge 3 is totally and completely dead. No bluetooth connection. Nothing. It is a piece of black glass--pretty, but useless. Thus, there is no point in continuing to wear it.
01-06-2019 12:22
01-06-2019 12:22
NorrhernLights9,
I got that same shpeel about the "higher office" email in 2 to 3 days from this morning when I contacted them with my issue and mine was 13 hours old out of the box. I feel your pain and frustration.
01-06-2019 12:43
01-06-2019 12:43
27CJ27,
Your situation is even more annoying than mine!
01-06-2019 13:30
01-06-2019 13:30
01-16-2019 10:29
01-16-2019 10:29
Another solution I found, as the reset was not working, was changing the clock face from the App. That also "resets" the fitbit and it works again.
Regards
Best Answer01-16-2019 10:33
01-16-2019 10:33
Thanks for sharing your successful strategy, Pablo. My tracker was so dead that it had no bluetooth connection to my phone or laptop, so I could not change anything on it. I've since received a new one from Fitbit, and after six whole days, it's still working. I have my fingers crossed that I won't need to try your strategy soon.
Best Answer01-19-2019 05:48
01-19-2019 05:48
I am having the same problem. The reset did not work for me. Any other suggestions?
Best Answer01-19-2019 06:11
01-19-2019 06:11
No, Sorry. I ended up going through Fitbit Customer Service for a new tracker.
Best Answer01-19-2019 06:14
01-19-2019 06:14
It seems that none of these methods for resetting the watch, charging or changing clock face seem to be working for me. I like the size of this device and functions which is why I chose it. Hoping an exchange will remedy the problem. I had an Apple Watch and didn't like to use it due to size on my wrist, and length of charge. Hoping I do not have to go back to it!
