10-11-2018
07:46
15:06
10-11-2018
07:46
15:06
So I got mine a couple days ago but the touchscreen does not seem to be working. I tried swiping every which way and restarting the device multiple times but still nothing. I even had someone else try it in the event I was doing something incorrectly but still nothing. Tapping on the screen does nothing either. Anyone else having issues with it?
01-19-2020 18:29
01-19-2020 18:29
Still not sustaining the ability to respond to touchscreen.
Best Answer01-19-2020 19:47
01-19-2020 19:47
Best Answer01-20-2020 18:59
01-20-2020 18:59
Hello,
I have a problem with my fitbit charge 3 it vibrates and the screen turns on, but the touchscreen isent working so I cant scroll down and I cant select an exercise what would be the best thing to do please?
Best Answer01-20-2020 21:34
01-20-2020 21:34
01-20-2020 23:42
01-20-2020 23:42
Did you have anything like this just dont know if I can reset it or if it's broken
Best Answer04-21-2020 08:17 - last edited on 10-11-2020 20:12 by LiliyaFitbit
restarting my Fitbit resolved my issue of the touchscreen not responding to my swiping it with my finger. It worked as soon as I restarted it. Thank you.
Moderator edit: format
Best Answer05-15-2020 23:34
05-15-2020 23:34
My fitbit versa is not touch sensitive....
Best Answer08-14-2020 06:53
08-14-2020 06:53
Worked for me. Thanks.
Best Answer10-11-2020 03:34
10-11-2020 03:34
Hi forum
I'm having a similar problem, the bottom half of my screen will not respond to touch, I've restarted it several times to no avail and I cannot physically do a factory reset because it's at the bottom of the settings on the watch
Is it possible that it needs to be repaired/replaced? I've had it just under a year
Please respond
Best Answer10-11-2020 06:50
10-11-2020 06:50
Didnt work for me ..another suggestions please
