Okay, to explain. At first all was great. When first started using Charge 3 Fitbit, I could change settings in the App on my iPhone XR, such as brightness, alarms etc. Easy peasy. Perfect as easier to see. Then, about a year to 18 months later, did an update which MOVED the ability to change settings to the Fitbit itself. There the problems started. I would sometimes accidentally brush the screen, and it would change settings, esp the brightness, and then total darkness. No biggie so just kept using as a tracker only which i could see stats on my phone. But somehow, my Fitbit disconnected from the App and when prompted to type in 4 digit code that should show on Fitbit display screen, guess what….I can’t see it. Dark pitch black screen, remember? 😢 Is there a simple solution? Please help. Thank you.
@KG1966 , A warm welcome to the Community! Thank you for your message and efforts.
If you haven't done so yet, please give our team a call or chat with them . They'll be more than glad to assist you further.
Tap here to get connected with Support.
Fill up the form, you'll get some articles recommended.
Then you'll see the options to contact Support.
