03-03-2019
12:53
11:22
03-03-2019
12:53
11:22
IveI've my Charge 3 since October 2018, recently while wearing it, the screen wake wasn't working or coming on when tapped, then the button on the side was not registering either. I thought maybe the battery had died, so I charged and reset it, but once it came back on, it continued to flash the screen on and off while also vibrating like I am pushing the side button repeatedly. Resetting is not working, I bought it from REI but don't have the packaging anymore.
Best AnswerI have the same issue. My charge 3 keeps vibrating on movement. I did the short and long resets. Please help.
Best Answer05-31-2020 07:29 - last edited on 09-30-2020 20:26 by LiliyaFitbit
My Fitbit charge 3 is blinking and vibrating also. I have tried your advice for a long restart and reboot but neither worked. My app has been uninstalled and reinstalled. However my Fitbit is still blinking and vibrating. I appreciate your time and help.
thank you very much,
Best AnswerMine also has the problem and the long reset did not change the situation. Is there another remedy?
Best AnswerSame problem for me. Can't get the restart to work either and it won't connect to my phone to even try to change the clock face. When I have it plugged in it show a download progress bar that is full, but doesn't change.
Best AnswerI am having this same problem. I can see that several other users have been experiencing this same issue between 2019-20. My Fitbit Charge 3 all of a sudden started vibrating randomly and flashing random screen displays. I have already followed the reset process, whilst in the charging cradle etc etc, which didn't work. Numerous times. The reset progress bar clicks along 1,2,3,4,5,6.... then black, then smiley face, they the random stuff just starts all over again. I have already had to replace the first one under warranty within about 6 months from the battery overheating problem that I can see on this Community Board too. But this replacement one is only about 10 months old. What should I do?...
Hello everyone. @architect_greg. Welcome to the community forums.
Thank you for taking the time to provide your feedback and for following some troubleshooting steps. Please note that our team is always working to enhance your experience and your feedback is a big part of that process.
On a side note, if the restart hasn't helped, my best recommendation is that you please reach out to our Support Team for further assistance. Take into consideration that replacement devices are provided for products that are within the warranty period. If your original Charge 3 is no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information about our warranty policy, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty.
See you around.
