07-12-2020
14:57
08:40
07-12-2020
14:57
08:40
Earlier Fitbit Charge 3 showed a different screen ‘Screen Wake and Notifications. Tried to remove them couldn’t. So restarted the Fitbit. No change.
Saw suggestions to change the clock face. Did this twice. Screen still displayed Screen Wake and Notification.
Have now restarted 3 times. Tried changing clock face again - now iPhone can’t find the device.
Now buzzing and flashing different screens. So have had to take off.
Bought August 2019.
07-13-2020 18:39
07-13-2020 18:39
Welcome to the Fitbit Community, @GG888.
I appreciate your participation in the Forums and sharing the issues you're experiencing with your Fitbit Charge 3. Thanks for trying to resolve this, I appreciate the additional details and I am here to help. I've shared your post with our Support team and they've mentioned that you already have a case with them. I know they will be glad to help you out and provide a solution, please keep an eye on your inbox.
Let me know if you have any questions.
Best Answer07-13-2020 18:51
07-13-2020 18:51
My Fitbit Charge 3 is having the same issues...been going on for a few days
Let me know if there’s a way to resolve to problem
Best Answer07-15-2020 18:25
07-15-2020 18:25
Welcome to the Fitbit Community, @Audacious883.
Thank you for joining the thread and sharing that you're experiencing the same issue with your device. I am glad to assist you. I recommend trying the following:
Additionally, I recommend checking if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
Let me know how it goes, I'll be around.
Best Answer07-16-2020 02:32
07-16-2020 02:32
I did all if that the day before, several times, didn’t work. Just sent the watch into a buzzing/flashing frenzy. Recharged did it all again. Battery went flat in no time. Reset, plugged into PC. No change.
Next day all worked again??? What was that about!
Best Answer07-16-2020 03:30
07-16-2020 03:30
My Charge 3 (10 months old) was working well till it went into a sudden and inexplicable fit of incessant vibrating and flashing and unstable screens. The battery crashed in minutes and thereafter the usual attempts of recharging, rebooting and resetting data proved to be futile. I connected it to my Mac and a horizontal while line across the center of the screen is all I got - until I disconnect it, and it goes totally dead.
Best Answer07-16-2020 05:23
07-16-2020 05:23
I have restarted and rebooted my Fitbit Charge 3 multiple times and sadly the issues are still present.
Best Answer07-16-2020 05:39
07-16-2020 05:39
Exactly what happened to my husband’s. Tried everything several times. Guess what after 24 hours, it’s back to normal Must be some sort of glitch at Fitbit’s end?
Best Answer07-16-2020 06:03
07-16-2020 06:03
This is all happening to mine, too - vibrating incessantly, going back and forth between screens. It won't connect to my phone, it won't restart, but it does charge. Not sure what else I can do with this level of unresponsiveness from the charge 3.
Best Answer07-16-2020 21:57
07-16-2020 21:57
I'm glad your husband's Charge 3 got OK.. mine continues to be dead and no amount of coaxing, cajoling, hoping or restarting seems to work. This is the THIRD Fitbit that I've had go nuts on me over the past few years and much as I like my Fitbit, I really ought to find a a more reliable alternative.
Best Answer07-26-2020 08:43
07-26-2020 08:43
Mine is currently doing exactly the same.
Really annoyed at a lack of customer support on this.
Can anyone suggest a better tracker system?
08-21-2020 00:00
08-21-2020 00:00
Hi.. My under-warranty Charge-3 'seemed' to come back to normal but the readings and Heart Rate were dangerously misleading. I've now been waiting TWO MONTHS for my replacement and FitBit does not have a CLUE as to when I will get it. This is a ridiculously poor level of customer support I'd reckon. This message probably needs to be a tweet or on Insta for someone at FitBit to react.
