Charge 3 won't charge
Hi, my Charge 3 will not charge up. When i place it in the charging cradle and hold the button for 8 seconds one of two things happens. I either get the smiley face for a moment, and then it disappears, alternatively i get a white progress bar that that moves across the screen left to right, and when it gets to the right hand side of the screen it just stops. when i take it out of the charging cradle, it goes back to having a blank screen.
it feels as though it tried to do some update and failed. anyone else experienced this and do you have any suggestions please? thanks
1 REPLY 1
Welcome to the Community, @Luciarivera.
Thanks for troubleshooting this battery issue. If your Charge 3 isn't charging, I recommend taking a look at the help article: Why isn't my Fitbit device's battery charging? and follow the instructions provided there.
Now if the issue is with the tracker not turning on, I recommend following the steps in this post.
Let me know the outcome.
