04-22-2021
05:26
05:37
WilsonFitbit
04-22-2021
05:26
05:37
WilsonFitbit
I have tried restarting it - I have cleaned the charging portion. When it is plugged in how many green lights should be on - when I look at the back of mine only 1 light is on
I don't know if I need a new charger or what to do but it is not charging I am down to 5%
Has anyone else had this issue?
Hello @cam21. Welcome to the community forums!
Thank you for the detailed information and for the troubleshooting steps you've tried prior to posting. If your Charge 3 refuses to charge even after following these steps, I recommend performing a long restart. You can perform this by following the instructions below:
Take into consideration that Charge 3 vibrates, and a battery icon appears on the screen to indicate that it is charging. For your question about the lights, I think the lights will blink once it is fully charged.
Hope this helps.
