11-01-2020
01:21
13:03
11-01-2020
01:21
13:03
So yesterday my Fitbit charge 3 would not light up . I read by changing the clock face it would fix this issue. When trying to sync my Fitbit the app it self would not open . So I uninstalled the app and re installed it. Now it's trying to set up my Fitbit again . Only problem is my Fitbit won't show the code as the screen in my Fitbit won't work . Any ideas . It's only 5 months old
11-02-2020
07:26
08:40
11-02-2020
07:26
08:40
@Kinghthood Welcome to the Community.
Let me help you with your Charge 3 screen not working and thank you for troubleshooting this issue. When using the Fitbit app make sure you are selecting the Log in option and not the Join Fitbit option as the latter will guide you the setup process. Also when you remove the app this doesn't remove the tracker from your account this is why it is odd that you are getting the prompt to set it up again unless you removed it. Regarding the tracker please restart it by doing the following:
Let me know how it goes.
Best Answer11-02-2020 07:57
11-02-2020 07:57
My Charge 3 is not over 1 yr old. The face has gone so dim that it is difficult to read. I followed these instructions to restart and was successful, smiley face and all, but the face remains as dim as ever. please. help.
10:50
04:25
11-03-2020
10:50
04:25
@PFRass I hope you're doing well!
Thank you for restarting your tracker by following my previous instructions. Are you able to navigate to your tracker's settings? Make sure the setting isn't on Dim for the brightness option also make sure it isn't in sleep mode by long pressing the button.
I look forward to your reply.
