12-04-2019
21:24
10:29
12-04-2019
21:24
10:29
My fitbit charge 3 keeps glitching and vibrating. Fully charged. Only had it for a few months. I rely on this thing way to much for it to not be working.
12-05-2019 05:17
12-05-2019 05:17
Hi @LaDonnaPace, welcome to the Community Forums. Thanks for the details provided about your Charge 3's behavior.
First of all, please try @WendyB's recommendation. 😉
In case that the restart doesn't work, I'd suggest restarting your Charge 3 using the 15-second method:
If the long restart does not work either, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome. I'll be around and willing to create a support case on your behalf if necessary.
Best Answer12-04-2019 22:22
12-04-2019 22:22
Welcome to the forums!
Try a restart do it 3 times
If that doesn't help contact support. Use Help link at top of forum
Wendy | CA | Moto G6 Android
Best Answer12-05-2019 05:17
12-05-2019 05:17
Best Answer08-09-2020 21:26
08-09-2020 21:26
I am having the same issues. I've tried the restart suggestions, it is still synching and have tried changing the clock face multiple times. Nothing has worked - it is very frustrating. Not old enough to stop working!!
