11-19-2018
06:53
14:31
11-19-2018
06:53
14:31
I had already tried to set it up as new device on my Android phone but, although my phone"saw" the FB3 during the set up, it couldn't connect with it. It did not connect or synch until I unpaired it completely with Bluetooth on my phone- and did NOT re-pair it. Then it started synching!? What is that about?? My new theory is that it is not as waterproof as advertised and I've been taking it off while in shower or washing dishes and so far, so good. But, nonetheless, this charge 3 has problemsthat need to be corrected ASAP!!
It's nice to see you around the forums @8113sally! Have you checked if your phone is included in our list of supported devices? You can see: Which phones and tablets can I use with my Fitbit watch or tracker?
If your phone is compatible with the Fitbit app and your Charge 3 is not syncing, try the troubleshooting steps provided in the article: Why won't my Fitbit device sync?
Give this a shot and let me know the outcome!
Hmmm... this is very strange @8113sally. Thanks for sharing with me those details, I'll keep an eye on that.
I'd recommend restarting your Charge 3 to refresh it internally:
Test your tracker the next couple of days and let me know if there's anything else I may assist you with.
Best AnswerI just talked with customer support and still no resolution to problem. I really think Fitbit should offer a refund or replacement for this defective product. They should also discontinue selling the Charge 3 until it is working properly with the Android cellphone.
So the Oneplus 6 is listed, but not the Oneplus 6T. And, it doesn't sync. It did sporadically, but now nothing. Am I to understand that the Oneplus 6T is incompatible with the fitbit Charge 3?
13:18
11:55
AndreaFitbit
01-09-2020
13:18
11:55
AndreaFitbit
I have a Huawei P10. It's an android phone. I've been having the same issues. I never get notifications to my Fitbit 3. I just cleared all my user data on my Fitbit. It synced in two seconds after that. And I just received a text notification. Super weird.
Moderator edit: format.
Best AnswerThis is happening with my Charge 3 tracker. The only time the Charge 3 reliably synchs is when the battery is completely charged. I also notice that my battery doesn't last five days anymore, more like 3 days. To me, this is an indication that the battery has a lot of serial resistance in it. And when the Bluetooth function is used, the serial resistance makes the voltage drop where the Bluetooth transmitter works marginally at best. So, I think there is a battery issue.
