05-17-2021 13:06
05-17-2021 13:06
I have had 3 Charge 3 trackers and the latest one has done the same as the first two. After a few months the synchronising stops. Nothing will make it reconnect.
05-18-2021 10:42
05-18-2021 10:42
Welcome to the Fitbit Community, @Mep123. I'm sorry to hear your Charge 3 stopped syncing and that nothing will make it reconnect.
Could you please confirm that you have followed the steps of help article: Why won't my Fitbit device sync? Please provide more information about what happens with your device when you try to sync it.
Keep on visiting the forums.
05-19-2021 09:24
05-19-2021 09:24
Best Answer05-19-2021 10:56
05-19-2021 10:56
I am having the exact issue. I'm only on device 2 though.. Not 3.
05-19-2021 11:30
05-19-2021 11:30
Best Answer05-19-2021 11:37
05-19-2021 11:37
Best Answer05-21-2021 07:31
05-21-2021 07:31
Hi, I can confirm that I have done everything in the article. It did manage to sync once and the data appeared on my app but now it wont do it again. The time is wrong again and I dont want to have to go through the reset every day.
05-21-2021
09:24
08:02
AndreaFitbit
05-21-2021
09:24
08:02
AndreaFitbit
Agree. I can't get my 3 to sync. I've done everything requested in this forum so far and it's not working.
What do I need to do?
Moderator edit: format.
05-21-2021 12:26
05-21-2021 12:26
Same here. Doing my nut in!
New version 4 about now, so ours will keep falling until us Charge 3er's buy an upgrade!
Best Answer05-21-2021 13:18
05-21-2021 13:18
I have the same problem. I'm thinking if I have to buy a new one again I'm buying a galaxy watch.
05-21-2021 14:53
05-21-2021 14:53
Best Answer05-21-2021 18:39
05-21-2021 18:39
Best Answer05-22-2021 05:55
05-22-2021 05:55
It's an ongoing issue since the last update. Is Fitbit working on a fix? Is there a time when we can expect this to be fixed or are we better off switching to Garmin?
05-22-2021 07:12
05-22-2021 07:12
I too have tried everything listed and it won't sync. And now I can't even pair it at all either. I'm on android OS
05-22-2021 08:17
05-22-2021 08:17
I have a Fitbit Charge 101. I had last used it in 2015 due to some family and health issues. I'm now ready to get back to making me healthier and am sad to find out I cannot sync this fitbit. It knew me when I installed the app again. I use Win10 and no bluetooth. It won't reset to the correct time even though I have the correct timezone set. I can't even get it to do a reset using the hold the button on the wrist device. I've followed everything in the manual and on youtube, wikihow, etc. I even removed the device from my account and reinstalled the app for Win10 three times. Now it won't add the device to my Fitbit account. The firewall is open to Fitbit. If anyone has any suggestions, I'm happy to try them. As for now, I guess I'll just do without my Fitbit. I can't even email support, they only use Twitter. I do plan to try the Chat or the phone on Monday. But I'm not hopeful they can help unless I can go back to the 2015 software.
Best Answer07-02-2022 07:52
07-02-2022 07:52
Hello Andrea, there is clearly a significant problem with the fitbit software. You (as a company) refuse to use the Android/iPhone pairing systems for bluetooth devices. That alone is a warning sign.
Having to turn off the app isn't a solution. It's a sign the software isn't good enough. Having to stop Bluetooth is also unacceptable. What if other devices are using it? Then the last option is to restart the tracker - which doesn't solve the problem.
There's a glaring bug. Add some debugging to your code and fix the underlying problem.
