Charge 3 won't turn on
Charge 3 display not working. I've done the reboot and still no luck.
2 REPLIES 2
Hi @Commish3  Please also try a Long Restart and try changing the clockface in the app. If the issue remains after this then contact Support
Fitbit Support
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Community Council Member
Helen | Western Australia
Welcome to the Community, @Commish3 and @NellyG, thanks for the input.
I appreciate all the efforts in trying to fix this display issue. Also, I was able to see here that our friend @NellyG provided some instructions in order to fix this problem. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
