06-15-2020
05:35
10:08
AlejandraFitbit
06-15-2020
05:35
10:08
AlejandraFitbit
Please help, my charge 3 just switched off. Battery was not even empty. I've tried restarting by plugging charger on and holding button for 14 seconds still no response or usual vibration feedback.
11-05-2020 10:09
11-05-2020 10:09
Best Answer11-05-2020 10:11
11-05-2020 10:11
Try this
Found out the device was put into the sleep option, if you plug it in, hold the button ..in a dark room..and the sleep option should be visible, touch that. Worked for me. You and I aren’t the only ones..
