05-14-2020
09:25
08:52
05-14-2020
09:25
08:52
I've been through all the community posts and done all the options. Making sure notifications are on and not toggled off on the Charge 3 itself. I've reset it and resynced with Bluetooth, etc.
I first had noticed it's not vibrating for calls or texts but then as I dug further I discovered it won't do it for silent alarms, when I turn it off and back on, when I put it on the charger, or when I start the stopwatch.
Any other options other than waiting on hold with support?
Welcome to the Forums, @BethMans.
Thanks for troubleshooting this vibration issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
