07-15-2020
11:57
16:44
07-15-2020
11:57
16:44
I've had the issue that my Charge 3 had a blank screen but still vibrated, I did get that one replaced. The replacement one, everything from display to alarms were working well for about 3 months, but now the screen display is working besides vibrating (the whole point of getting notifications through Fitbit).
I've set myself alarms and timers to see if the Charge 3 would go off, but not even then. This has also happened a day prior, with that I just let my Fitbit sit for a while then put it back on and was working (vibrating). My question or concerns are how do you get notification vibrations back, or why did this happen?
08-03-2020
11:44
04:28
08-03-2020
11:44
04:28
It's great to see you around, @Macaroon44.
Thanks for troubleshooting this vibration issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
