@BenWyles , Nice to see you here. Thank you for your message and report.
Have you tried changing the brightness settings in the Charge 4?
Have you restarted your tracker?How do I restart my Fitbit device?
See you around.
05-17-2022
19:27
18:35
JuanFitbit
05-17-2022
19:27
18:35
JuanFitbit
How do I change the brightness setting?
*Ben *
Life is not about avoiding the storms; it's
about learning to dance in the rain
Moderator edit: removed personal information
Best AnswerHello @BenWyles
I can tell you how to adjust your brightness settings. To adjust the "Brightness" setting swipe left from your charge 4 clock screen to and touch "settings". The first setting you are offered is "Brightness" you can touch this to toggle between auto, dim or normal. After setting this touch the side button twice to return to the clock screen.
If this does not work you may have inadvertently engaged "Sleep mode", touch the side button for about 2 seconds and you will get "Do not disturb", "Sleep" and swipe up for "Screen wake" The first 2 need to be off and screen wake should be on if you want to use the wrist flick action to illuminate your charge 4 screen.
😃 Please let me know if this indeed provides you with an answer…..oh yes..dancing in the rain is an art that so few have truly learned to perfect but so necessary indeed.😉
05-18-2022
05:48
18:36
JuanFitbit
05-18-2022
05:48
18:36
JuanFitbit
Thank you very much! I have no idea how those settings changed.
Benjamin
