@Bainie , Nice to see you here.I don't have it on the top of my head, how many pins does the charging cable has/needs.
But you can always purchase the original charging cable for the Charge 4 on our online Shop. https://www.fitbit.com/global/us/products/accessories/charge4-charging-cable?sku=172RCC
Best Answer@Bainie I changed the ../us/.. to ../uk/.. in the URL and found it for you in the UK Store: https://www.fitbit.com/global/uk/products/accessories/charge4-charging-cable?sku=172RCC
BTW, I have an original Charge 4 charging cable. It only has 2 pins. It's up to you to choose the original or a third party charger. I also have other older Fitbits with three contacts, but the charger only has two pins.
Laurie | Maryland
@LZeeW wrote:@Bainie I changed the ../us/.. to ../uk/.. in the URL and found it for you in the UK Store: https://www.fitbit.com/global/uk/products/accessories/charge4-charging-cable?sku=172RCC
That seems to be the problem. All the chargers I have seen have 2 pins but my Fitbit has 3 charging points and the 2 pin chargers don’t work Just can’t fin a 3 pin charger so perhaps they are no longer available.
@Bainie My link is to the UK store, so the item is an original charger. If you are having trouble, try scrubbing the charging contacts with some alcohol and a very soft toothbrush. I use a toothbrush for a small child. You might have corrosion that is keeping you Fitbit from charging.
Laurie | Maryland
