09-19-2022
07:00
13:08
09-19-2022
07:00
13:08
My fitbit was not used for 6 months. On 7th month I put it to charge and I realize it's not working anymore. Ah.
Only green light is blinking but the display is not coming up. I am so helpless.
I tried connecting it to pc, kept it in charge for very long, but nothing is working. Just green light displays and it vibrates in return.
09-19-2022 18:44
09-19-2022 18:44
@BharatChhajed , A warm welcome to the Community !Thank you for your message and for trying to charge the Charge 4 longer.
Please do as follows
4 . Press and hold the button on your tracker for 8 seconds. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
Hope this helps
Best Answer09-23-2022 09:24
09-23-2022 09:24
I have been using my Charge 4 daily and last week it suddenly went black. Green light still came on, still vibrated , still syncing with the phone app, just no display. I tried everything suggested (reset, etc.) and contacted Fitbit Support. Was told there was no more they could do and I would have my case referred to the warranty group. In a matter of a couple hours I received an email advising me my warranty had lapsed (which I knew) and offered a 35% discount. OK, so I bought a new Charge 5 which I like quite a bit and it arrived quickly. It set up and connected easily and I was ready to go. I then picked up the old "dead" Charge 4 and lo and behold it came to life and is working fine.
Disappointed that I got no elevated support and was just told I needed to buy a new one. Unfortunately, this is pretty typical of Fitbit support.
