01-04-2022
11:41
16:01
01-04-2022
11:41
16:01
I mainly get my steps on a treadmill. At the end of my workout the treadmill will read ex "1.5 miles", but my watch will only track "1 mile".
01-04-2022
17:11
09:20
01-04-2022
17:11
09:20
Hi @dianelevy19 , Nice to see you here. Thank you for your message.
When you are on the treadmill, do you have your hands on the railings? This can avoid that some steps are recognized so that your distance is lower as the one shown on the machine.
Hope this helps
Best Answer01-05-2022 07:05
01-05-2022 07:05
Good Morning.
I never have my hands on the railings.
16:40
09:20
01-05-2022
16:40
09:20
@dianelevy19 , Thank you for your reply and confirmation.
Please customize your stride length. If you do bigger steps during your run on the treadmill, as the average, it's recommended that you edit the ones assigned. More about this can be read here: Can I change my stride length in my Fitbit account?
Hope this helps
Best Answer01-05-2022 16:46
01-05-2022 16:46
Hello @dianelevy19
Estimation of distance is done via steps multiplied by stride. Since you are running indoor the GPS is of course not in use (kindly confirm you are using GPS off) but stride could have been estimated wrongly by Fitbit.
To check (and eventually correct) the stride open the Fitbit app in your phone, press your avatar on top left, then under settings press "Activity and Wellness", then "Exercise" and finally "Stride Lenght" .
Deactivate "Set automatically" and input your Walking/Running stride Lenghts manually.
After few runs I'm confident you can estimate the right stride, for now my suggestion is to input a value a big higher than what automatically set since your Fitbit is under reporting.
Let me know if you need further help.
