03-05-2023
11:23
12:38
03-05-2023
11:23
12:38
Hello,
The GPS is on. When I start to run, I start the
the device tries to connect. But after a fiew minutes I get a message that the connection was not possible.
How can I solve this?
03-06-2023 12:41 - edited 06-03-2023 11:10
Hi there, @lieswi. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 4.
GPS dropouts can be caused by several things (tall buildings, trees, overcast, etc.). Please take into consideration the following information when using GPS:
Make sure that you have a clear view of the sky when you start the exercise. Environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
For more information about GPS, see How do I use GPS on my Fitbit device?
Best Answer03-06-2023 12:41 - edited 06-03-2023 11:10
Best Answer03-17-2023 01:37
03-17-2023 01:37
Thank you for tje information. I have verified all these points.
I have the devise since februari 2022. The gps has always worked properly untill one month ago.
I have checked several times: device is fully charged, the sky not clouded, no tall buildings but still it doesn't connect or falls out again after some minutes.
My device is in guarantee. Can i send it back for check and repair?
Thank you
