01-11-2023
11:39
17:20
LucioFitbit
01-11-2023
11:39
17:20
LucioFitbit
Hi there. My charge 4 is about a year old. The clip has broken. I think the actual plastic snapped. How can I fix this? See pics. Thanks
Moderator Edit: Clarified subject and Labels
01-12-2023
17:24
08:45
01-12-2023
17:24
08:45
Hi there @NickyP1977. Welcome to Community Forums.
I appreciate you reach out to the Community. I'd recommend you check this thread, where another user suggest a way to do it yourself.
If this doesn't solve your issue please contact Support Team.
Best AnswerThe same thing happened to mine and since it was out of warranty could not get it replaced. I was just offered a discount on the purchase of a new one. Meanwhile the tracker itself is working fine. I googled holders for trackers on Amazon and found a bracelet with a little pouch you can insert your tracker into and wear it as before. My tracker is now on my wrist and working fine. It fastens with velcro. Problem solved. But it is a definite design flaw in the plastic housing of the tracker.
Best AnswerThe item I bought from Amazon was called Chofit Bands compatible with Fitbit Inspire, Charge and more. You get 3 in a package and choose the size that can fit either wrist, arm or ankle.
17:32
08:45
01-16-2023
17:32
08:45
Hi there @soleilsnana, it's good to have you in the Community.
I appreciate the information shared, I'm sure many users will benefit from it. I'd like to invite you to visit our Health & Wellness board where you can share your experiences, meet people and create new topics.
