02-18-2022
23:41
15:30
02-18-2022
23:41
15:30
My Charge 4 is 12 months old
Recently the battery died so I put on charge for a few hours but when I returned to it, it still wouldn’t switch on. Left overnight but still the same the next day.
Green sensor still flashing on back so managed to reset and sync and it seemed to work ok
The next day the battery had gone completely flat again (normally lasts a few days). Recharged, worked for another day, the. The screen went completely blank and the only way to get it working again is to reset it??
Worked absolutely fine up until this point. Is it completely dead????
Thanks
02-19-2022 06:54 - edited 12-26-2023 08:21
Hi there, @Louise1985. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
It seems like the battery might not be charging properly. With that said, I'd recommend taking a look at this help article Why isn't my Fitbit device's battery charging?
If the issue persists after a few days, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer02-19-2022 07:57
02-19-2022 07:57
Hi, Contact Fitbit Support because the warranty is only for one year with a 30 day grace period. If they can’t help
you fix the problem, hopefully you will fall into the grace period for a replacement. Good Luck
