12-02-2022
20:00
15:33
12-02-2022
20:00
15:33
My charge 4 is lasting only two days from full charge since the display bug was fixed last week.
Using it normally, it’s not under any load. Is this another bug?
Hi there, @Marillad. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Charge 4.
Please note the battery life will depend on how frequent certain features are used such SpO2 tracking, Spotify app, and so on. This doesn't mean that you shouldn't use them, but it's to take these conditions into consideration.
I'd recommend following the tips described in this help article to maximize the battery life, fully charge your Charge 4 using the charging cable that came in the box and monitor its behavior in the next days.
If by any chance you face another display issue, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
