04-18-2020
10:27
16:20
04-18-2020
10:27
16:20
My watch is consistently getting 3 hours of battery life. I’m not running GPS and I adjusted sync settings, which made absolutely zero difference. I’ve tried rebooting and I’m beyond frustrated. This is my first Fitbit product and I’m very disappointed so far!
04-18-2020 10:30
04-18-2020 10:30
If you’re certain gps is off it sounds like it’s just defective and needs exchanged. I’m at 50% after 3 days and a couple updates installed
Best Answer04-18-2020 11:39
04-18-2020 11:39
I’ve never turned it on. The only place that I’ve saw to turn it on or off is under exercise in settings. It is set to be on during running, walking, and hiking. I haven’t done any of those and so far. I’m pretty sure it’s defective, but I want to be 100%. Customer service didn’t go through any of that. They had me reboot it and that was it. So I’m willing to try anything.
04-18-2020 12:17
04-18-2020 12:17
Mine was charged to 100% this morning, I went for an hour and a half run and it's now drained to 48% by evening. This can't be right.
04-20-2020 10:41 - edited 04-20-2020 10:45
Hi @garland.daniel and @Lempi1, welcome on board. @Holeweet, it's great to see you here in the forums and thanks for sharing your insight. I'm sorry for the delayed response.
@garland.daniel, thanks for bringing this to my attention, as well for troubleshooting your Charge 4 prior posting. I got in touch with our Support team and I was told that you already have a case opened with them which is under review. They'll contact you back via email with more details. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
@Lempi1, thanks for sharing that your Charge 4 is also not holding charge. Just to confirm, may I know if you used GPS during your run? Have you used other apps regularly on your tracker, such as Spotify? I'm asking this as the battery life of your tracker will depend on how often some apps are used. You can find more details in this help article. Let me know if this issue persists despite having taken those tips into consideration.
I'll be around.
07-01-2020 16:00
07-01-2020 16:00
I have a brand new fitbit, also first time user. My battery is also depleted after 3 hours, and I have trouble syncing with my phone.
07-13-2020
16:07
18:37
07-13-2020
16:07
18:37
Hi @Taminy. Welcome. It's great to see a new face around and I'm sorry for the delay.
Thanks for letting me know about your experience with the Charge 4 and let me help you with each of your inquiries. As with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS tracking or even the Spotify app. This doesn't mean that you shouldn't use them, but just to take into consideration the conditions that may affect your tracker's battery. Please try the tips to maximize the battery life described in this help article and make sure to use the charging cable that came with your device.
About the syncing issues, do you see an error message on the Fitbit app? Since your post didn't mention, I'd recommend to give a try to the troubleshooting steps from this help article. If the same keeps happening, I'll need you to provide me with your phone's model and OS/software version.
I'll look forward to your response.
10-04-2020 12:28
10-04-2020 12:28
I am also facing the battery issue with my Fitbit charge 4, I am at home and gps in my Fitbit is off and I don’t use any other app on the Fitbit. Its on my wrist mainly to count my heart rate and track my sleep. After buying I fully charged it and in less than 4 days battery level was at 8%
10-05-2020
14:50
10:04
10-05-2020
14:50
10:04
Hi @K_NL. Welcome to the Community Forums.
Thanks for sharing that your Charge 4 isn't holding charge, as well for checking the factors that may impact the battery life. Because the battery seems to be lasting around 4 days, I've requested a case on your behalf so our Support team can take a deeper look. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
10-09-2020 03:03
10-09-2020 03:03
This is my issue too. I charged mine to 100% at 10pm last night and by 3am the battery was completely dead. Have re-set it and turned off GPS as all have suggested, and gone through to reduce notifications and anything else that might affect it. Also seen other things like gaps between pebble and band that I am experiencing. Have a long history with fitbit, and quality does seem to have reduced over the years.
10-09-2020 11:46
10-09-2020 11:46
I just purchased my Charge 4. Less than a day, basically using it as a watch & pedometer (no exercises, no apps, etc) and it goes from a 100% charge to 0% when Charge 4 is supposed to sustain a charge for 7 days. Very disappointed.
10-12-2020
13:52
10:01
10-12-2020
13:52
10:01
Hi @Janetrun1 and @jdk805. Welcome. It's good to have you on board.
Thanks for letting me know that your Charge 4 isn't holding charge and for trying the tips to maximize the battery life. I understand where you're coming from as you're not able to take advantage of your tracked due to its battery. Because this isn't the expected behavior of this tracker, I've gone ahead and requested a case so our Support team can look into this and provide you with assistance. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
06-20-2021 19:23
06-20-2021 19:23
went for a hike and out of battery not even half way (3hours). My friend's garmin lasted the whole day and was still at 60-70%.
I'm switching to garmin for sure, only had issues with those fitbit. GPS lost after 10min EVERY run, sync is a nightmare...
Best Answer06-22-2021 19:00
06-22-2021 19:00
06-22-2021 22:11
06-22-2021 22:11
I've had my Charge since November. It has worked great until the last week or so. The battery drops 10% as soon as I unplug it. Its completely dead after a few hours (it lasted for several days before this). I've been through the help feature and tried the suggestions. Any other ideas?
Best Answer06-23-2021 08:41
06-23-2021 08:41
My Charge 3 used to last six days. My new Charge 4 only lasted three days on the first full charge. GPS is off, screen is on Dim which is not usable in sunlight at all. Do these really last 'up to 7 days'?
18:15
10:02
06-25-2021
18:15
10:02
Hi @Lilwalt99. Welcome on board. @Janet_Stephen_T Thanks for bringing this to our attention.
Thanks for the details provided, as well as troubleshooting your Charge 4 on your own. I understand where you're coming from since the battery should last up to 7 days under normal conditions. If the tips described in this help article didn't help, I'd recommend getting in touch with our Support team so they can evaluate your options and bring you back on track. Please click here to get connected with them and make sure to share all the steps you've tried so far.
07-19-2021 14:13
07-19-2021 14:13
Hello, for about one week I've been having similar problems as other users with Charge 4. Did you guys update something? I certainly didn't change any setting, but my battery now lasts about a day, while before it was lasting 7 days.
I played with some settings and deactivated GPS (I did not know it was on, I certainly didn't activate it) and I'm charging it again, hoping it fixes the issue. In the meantime, perhaps you may want to check whether there's something else explaining this sudden Charge 4 battery epidemic.
Best Answer07-19-2021 14:25
07-19-2021 14:25
I was never able to get mine to stay charged. I used the online help (via chat). They were able to see the history of my Fitbit and see when the issue started. I told them everything I had already tried to fix the problem. After chatting a bit they simply replaced my Fitbit. It was an easy process but I don't think mine was fixable.
07-21-2021
18:35
10:02
07-21-2021
18:35
10:02
Hi there, @Lilwalt99. Welcome on board, @Archangelsk .
@Archangelsk Thanks for taking the time to troubleshooting your Charge 4. I'm sorry you've gone through this experience and please know your feedback won't be taken for granted as it'll help us to evaluate and improve our trackers. Because you've followed the tips to maximize the battery life, please monitor your tracker's behavior and get in touch with our Support team if the issue persists. You can get connected with them via chat or phone by clicking here.
@Lilwalt99 It's great that you're about to receive a replacement Charge 4 and thanks for keeping me posted. I'm sure they'll continue working on your case and bring you back on track, so please keep the communication with them.
