04-01-2024
04:11
11:05
04-01-2024
04:11
11:05
Hi
My charge 4 suddenly has a blank screen. I’ve tried to do a reset, the smiley face came up and then nothing else.
I've also tried changing the clock face and still nothing is displaying on the screen.
When I check the app the charge 4 is syncing. What else can I do?
04-01-2024 11:08
04-01-2024 11:08
Hi there, @Mike99999999999. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 4 is still not turning on. I will do my best to help you with this!
As per the description of your post, it seems like you're experiencing a battery issue. With that being said, please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Charge 4. I would recommend trying this maybe twice in a row if a first try doesn’t work.
If the above doesn't work, please see Why isn't my Fitbit device's battery charging?
