04-01-2024
11:03
11:14
04-01-2024
11:03
11:14
Is there a way to easily sync my charge to Fitbit to the correct date and time?
Hi there, @Madmomdavis. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 2. I will be glad to help you with this!
As a first approach, since you're running into syncing issues, please see Why won't my Fitbit device sync?
As you may know, the time will be wrong if your Charge 2 hasn't synced recently as your Fitbit device uses the time of the device you're syncing with. To make sure your Fitbit device has recently synced, go to your Fitbit app and tap the Today tab, and then tap Devices.
If the issue is still not solved, but you can confirm that your Fitbit device is syncing, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
