04-20-2020
01:24
16:20
04-20-2020
01:24
16:20
Hiya,
Just went on a run and began logging it as usual. However, there doesn't seem to be a way to then access Spotify controls if the Charge 4 is already logging a run. You can't do both simultaneously as the only way to access back to the main menu is to finish logging your exercise.
Surely this defeats the purpose of having Spotify on the device?
05-01-2020 07:43
05-01-2020 07:43
I suggest everyone add their vote to this Feature Suggestion to control music on the C4 while exercising. There should be music control on the Charge 4 like there are on the Versa.
04-20-2020 07:42
04-20-2020 07:42
I think this is a usability issue - maybe the designers didn’t consider that we would want to use the controls on the go. Or maybe it is a delayed feature, coming in a future firmware release.
04-20-2020 07:51
04-20-2020 07:51
Spotify is set up as a regular app. On the Versa you can get control of the music with a swipe down from any screen.
Something like this would be needed for the requested feature.
The other possibility would be to have the ability to move the tracking app to the background the way the timer can.
04-21-2020 03:57
04-21-2020 03:57
I know I can control Spotify by opening the app from the Fitbit charge 4 but I would like to know if this feature is also available when I start an activity (like running).
04-21-2020 06:16
04-21-2020 06:16
No. Makes it a redundant feature tbh
04-21-2020 07:02
04-21-2020 07:02
Yeah it's pretty useless... I need to change the music while I'm doing an activity and not when I have easy access to the phone..
04-21-2020 08:18 - edited 04-21-2020 08:20
Thanks for the clarification. My main gripe was that in their advertising it makes it seem as though you can do both at the same time on the Charge. As it's a fitness tracker most people would want to be able to control their music whilst logging an exercise. I would have got the Versa if the difference was made clearer as this was my main reason for getting a Fitbit.
Hopefully it'll get sorted in an update. There's been a feature request logged for it too.
04-23-2020 10:01
04-23-2020 10:01
I can't change songs on Spotify while exercising.
Anyone know how to do this?
Can't change the volume also.
HELP PLEASE!!!
04-23-2020 10:34
04-23-2020 10:34
I've combined a bunch of independent threads on this subject.
04-25-2020 17:04
04-25-2020 17:04
Is it possible to switch music tracks when in exercise mode? If not, is it being considered for a future update?
04-25-2020 22:30
04-25-2020 22:30
Hello @LostatSea007 I've moved your post to the existing thread on this subject
04-30-2020 03:47
04-30-2020 03:47
So clearly a feature that enticed me to the Charge 4, was being able to control Spotify from my wristband. Went out for a run today and realised that I can’t start my run on the watch and then switch the screen to Spotify to change my music without stopping my run. How is this appealing? Why can’t I still have my run being logged whilst controlling my music. Surely this is an obvious requirement for the function??
04-30-2020 06:23
04-30-2020 06:23
Same thing! If this is the case then it's a useless feature because I wont be stopping my workout to take my phone out to change a song.
Unless there is a workaround / fix for it - I'll be returning my fitbit. I can track my runs on any other basic device. Spotify was a main reason why i spend extra money on Charge 4.
05-01-2020 07:33
05-01-2020 07:33
Right now the best we can do is to add our votes to the suggestion.
Personally I wonder who designed the interface, not realizing that this is a must.
05-01-2020 07:43
05-01-2020 07:43
05-11-2020 05:55
05-11-2020 05:55
Hello all, I hope you are doing fine.
I am sorry for the delay in response and appreciate all the feedback provided about music control. As recommended, take a look at the Make Spotify accessible during a trackable workout request, vote for it and leave your comment.
Let me know if you need anything else. 🙂
Best Answer05-11-2020 10:43
05-11-2020 10:43
I came here looking for a solution and instead I found another link to upvote a feature that should already be in place. That seems to be the result of every thread.
05-15-2020 20:39
05-15-2020 20:39
Can we as users get an update from Fitibit on when this feature will become available?
Having spotify on a fitness tracker but not being able to use it concurrently with the exercising apps is totally not acceptable.
05-15-2020 21:48
05-15-2020 21:48
Agreed, the current implementation is just so flawed.
Best Answer05-16-2020 06:19
05-16-2020 06:19
Hey Guys,
Had same question around the Spotify functionality.
So easiest way to get this is to start the activity via your Fitbit Phone App and then adjust songs via Spotify on your FitBit.
All my numbers sync over from the phone to the Fitbit and seems to be the good workaround, I'm not sure if it is missing pieces of data but should be suiting for those looking for that flexibility while mid activity.
Hope this helps!
