08-17-2024 09:28
08-17-2024 09:28
Hi all,
I haven't used my charge 4 in awhile but yesterday decided to charge it up but it's not responding, it does the initial vibration when I put it in the charger but no battery charging symbol appears.
Have done the hard reset but nothing works.
08-20-2024 18:34
08-20-2024 18:34
Welcome back to the community forums @Reshape.
Thank you for sharing the inquiry regarding your Charge 4.
Since the Charge 4 is not one of the newest devices, it is possible that the battery is nearing the end of its life. However, I suggest you try the points listed in this help article: Why isn't my Fitbit device's battery charging?
Best Answer08-21-2024 06:23
08-21-2024 06:23
@ManuFitbit thank you for your reply,
I have tried all your suggestions apart from leaving it for 30 mins on charge so will try that tonight.
I have had the charge 4 for about 3 years but have only use it for about a week in that time and charged it once so would that still mean the battery may be at the end of life.
