03-13-2021
03:31
16:09
03-13-2021
03:31
16:09
I just purchased a Charge 4 this week. My device does not receive phone call and app notifications from my Android phone. I have checked all the settings on the app and the device mentioned in this article. I confirm that on the device, Do Not Disturb is off, Sleep Mode is off. On the phone, Do Not Disturb is off.
03-14-2021
10:56
03:59
03-14-2021
10:56
03:59
Hi @nikdeshp, welcome to the Community Forums.
Thanks for sharing the steps that you've tried on your own, you've done a good job. Because you mentioned this is affecting calls and apps notifications, may I know if the messages and calendar notifications are working well? Were you able to turn on the notifications for your preferred apps in the Fitbit app? Also, has the Fitbit app been allowed to run in the background? Please make sure your Android phone meets the requirements described here and let's give a try to the following steps:
03-14-2021
10:56
03:59
03-14-2021
10:56
03:59
The Fitbit app did not have access to the Phone, Calendar, and SMS apps. I just enabled these permissions. Now I receive phone call notifications on the device. I will check the others later. Thanks.
18:50
06:16
03-18-2021
18:50
06:16
Hi @nikdeshp, it's nice to see you here again.
I'm glad you're receiving phone call notifications on your Charge 4 and thanks for your efforts while working on this situation. Please check the settings of the other apps whenever you have time, try receiving a notification on your phone to test your tracker and keep me posted with the outcome.
See you around.
Hi I have tried these steps but I am still not receiving notifications is there anything elso that could work it keep telly me to restart my phone to enable notifications but I have done so many times and it's still not working
11-14-2022
17:40
06:15
11-14-2022
17:40
06:15
Welcome to the Community, @Kainelson.
Thanks for taking the time to troubleshoot your tracker prior to posting. I'm sorry you're having this experience and to look into this, may I know the model of your phone? Have you also follow the suggestions described in this help article?
In the meantime, let's try reconnecting your tracker to the Fitbit app as last resort by doing the following steps:
I tried what you said it didn't work it still says a phone restart is needed which I did and its still saying the same thing
Best AnswerI had to change the settings on the tracker to show Do Not Disturb is On. I realize that's strange. Also make sure that Sleep Mode is not enabled. Both those are under Settings on the tracker not in the app.
