03-03-2021
13:38
16:06
03-03-2021
13:38
16:06
My Fitbit went crazy and recorded an extra 43 603 steps in 1 hour only. I was cooking, so I do not know what had happened, but it is very frustrating! Any ideas how can I delete these steps? Many thanks
03-04-2021
05:29
03:45
03-04-2021
05:29
03:45
Welcome to the Community, @DorottyaLK.
I understand how are you feeling. For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
You can delete that extra information by following the steps in the article: How do I delete steps and floors in the Fitbit app?.
Have a good day!
03-04-2021
05:29
03:45
03-04-2021
05:29
03:45
Have a good day!
03-06-2021 05:00
03-06-2021 05:00
Thank you so so much!!!!!!!!! 🙂
03-07-2021
09:03
03:45
03-07-2021
09:03
03:45
You are welcome, @DorottyaLK. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
04-05-2021 01:00
04-05-2021 01:00
twice in the last 3 days I have woken up to find that my fitbit has registered over 40,000 steps at about 6am. Obviously I haven't done that many. What do I need to do please.
04-17-2021 15:36
04-17-2021 15:36
Happened to me too, last night between 1 and 3am, 23,000 steps while I was asleep, even my app said I was asleep. Hmmm I don't sleep walk! Very frustrating, advice needed! Thanks
Best Answer04-18-2021 00:46
04-18-2021 00:46
04-18-2021 02:37
04-18-2021 02:37
04-29-2022 05:48
04-29-2022 05:48
I checked and it was on in my account also. So unpaired, will see if it helps.
