08-16-2023
12:09
04:48
08-16-2023
12:09
04:48
I have a Fitbit charge 4. I do have my brightness set to NORMAL but the screen is still dim. I have restarted the Fitbit but still the same. Seems like the screen is going. when I set the screen to auto I can barely see the screen so I know I have it on the brightest setting which isn’t bright.
Any suggestion?
08-18-2023 04:52 - edited 08-18-2023 04:52
Hi there, @Psu92. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work, please check if your Charge 4 is in sleep mode. When the sleep mode setting is on:
To turn off Sleep Mode, please swipe left to access the quick settings screen. Tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it. For more information, see How do I navigate my Fitbit device?
08-18-2023 05:24
08-18-2023 05:24
Hi the device has been restated. Screen brightness is set to normal. Sleep mode is off.
I changed the screen to a bigger time it helps but is dim. Not sure there a fix and likely the fit bit is old. How do you turn off notifications?
08-24-2023 14:07
08-24-2023 14:07
Nice to see you around the community @Psu92.
Thanks for sharing with us the inconvenience about your Charge 4. I'm not sure if you still need help to turn off notifications:
To turn off certain notifications:
1. From the Today tab in the Fitbit app on your phone, tap your profile
picture > Charge 4 tile > Notifications.
2. Turn off the notifications you no longer want to receive on your tracker.
3. Sync your tracker to save your changes.
To turn off all notifications:
Press and hold the button on your tracker and swipe left to reach the quick settings screen.
Tap DND to turn on do not disturb. The DND icon dims to indicate that all notifications, including goal celebrations and reminders to move, are turned off.
Note that if you use the do not disturb setting on your phone, you don't receive notifications on your tracker until you turn off this setting.
08-25-2023 17:49
08-25-2023 17:49
You need a new one.
08-27-2023 17:58
08-27-2023 17:58
I am having the same problem, but my screen is so dim that I cannot see it well enough to do any of these steps. I can see that it's "on," but I can't make anything out, even in complete darkness.
08-28-2023 01:45
08-28-2023 01:45
Lots of people are suddenly having the same issue, I contacted support who offered 35% off a new one but if so many people are affected at once couldn't they do a software update to fix it?
08-28-2023 03:56
08-28-2023 03:56
Thanks for the info. Seems like the charge 5 has gotten bad reviews. It’s the only Fitbit I like. I will have to look around. Thanks again.
08-29-2023 05:57
08-29-2023 05:57
I only use the Fitbit at night, but I have also noticed recently that it is unreadable during the day. It seems to be much worse than when I first bought it.
