01-01-2022
08:08
16:01
01-01-2022
08:08
16:01
So here is the problem; all of a sudden the charge 4 screen on wristband is so dim I can't read what's on screen. The Device charges and syncs to mobile app so no issues there. To note: When you reset the device you do not see the smiley face icon
I have restarted the device, I have also tried changing the clock face as per the YT video solutions. All of which don't solve my issue.
One resolution talks about going to settings and then 'Brightness'. Is this on the desktop version as it's not on the mobile site or Fitbit app.
Any advice on resolving this issue would be appreciated. Thanks K
Best AnswerYou have do it on the Fitbit itself. Keep swiping left on the Fitbit and it’s the last screen that comes up. Chose settings and then go to brightness in there. Hope that helps
Best AnswerThanks for the info but the problem there is I can't see anything on screen so I am unable to navigate through to settings.
Best AnswerIt may be worth chatting online to the Fitbit help chat then. Have you tried looking in screen as Fitbit charging? Sorry not to be more help but the answer I gave solved te issue (although I did have to look v closely at the screen as was difficult to see due to dimness) good luck
