05-07-2022
11:30
10:51
05-07-2022
11:30
10:51
My display on my Fitbit is so dim I can’t see the clock or anything else…
05-07-2022 11:33
05-07-2022 11:33
Hello @JPCav
Its quite possible you accidentally changed your brightness level. To adjust the "Brightness" setting swipe left from your charge 4 clock screen and tap "settings". The first setting you are offered is "Brightness" you can touch this to toggle between auto, dim or normal. After setting this touch the side button twice to return to the clock screen.
😃 Please let me know if this answers your question and provides you with a solution.
05-07-2022 22:57
05-07-2022 22:57
Mine is so dim I can’t see settings - not good Fitbit I have a Fitbit I can’t see a click face I cannot see and no way of correcting it because …. I can’t see it
05-08-2022 07:35
05-08-2022 07:35
Hello @dorrinnda
Is there anyone who can adjust the settings for you @dorrinnda since it’s so dim you can’t see it? The adjustment settings is described in my previous post. I have poor vision (double vision) so I would need it brighter as well. My thoughts are maybe someone in your household or a friend can do it for you? Again just a thought.
01-24-2023 16:35
01-24-2023 16:35
Thank you it worked.
