05-02-2023
02:55
04:32
05-02-2023
02:55
04:32
My charge4 screen has suddenly gone so dim that I can’t read it.
I have reset the device but no change?
05-03-2023 04:24
05-03-2023 04:24
Hi, @TinaBerks , it is possible that the brightness setting has changed on your Fitbit. You will probably need to go into a very dark room to fix this! In the dark room, from the clock face swipe left all the way until you come to the settings menu. Tap to open. The first item on the menu is screen brightness, so tap that to toggle from dim to auto to normal. I find normal is the most readable in all lights. Auto makes it too dim for me in many circumstances. Dim and auto use less battery than Normal, but I don’t think it is much.
I hope this helps. Welcome to the forums.
05-03-2023 04:24
05-03-2023 04:24
05-03-2023 04:35
05-03-2023 04:35
Hi there, @TinaBerks. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 4.
In addition to the steps provided by @Julia_G, I'd suggest checking if by any chance your Charge 4 has the sleep mode feature enabled. When the sleep mode setting is on:
Sleep mode doesn't automatically turn off unless you set a sleep mode schedule. To schedule sleep mode to automatically turn on during certain hours:
If the above doesn't describe your issue, try restarting your Charge 4 to see if that helps. For more information, see How do I restart my Fitbit device?
05-04-2023 05:03
05-04-2023 05:03
Best Answer05-04-2023 05:03
05-04-2023 05:03
Fabulous! Solved it
thanks so much
Best Answer05-04-2023 06:38
05-04-2023 06:38
@TinaBerks I'm glad to hear your issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping.
Best Answer05-05-2023 00:58
05-05-2023 00:58
Fitbit Charge 4 and Charge 5 come with built-in GPS. Using this function drains the battery quite a bit. Switch built-in GPS on and the battery life comes down from 7 days to only 5 hours. Remember – if you forget to turn GPS off after exercising, it will eat up what's left of the battery life.
Regards,
Will
Best Answer05-05-2023 03:40
05-05-2023 03:40
I tried this. It doesnt work & is still extremely dim!
05-08-2023 15:29
05-08-2023 15:29
mine was always dim, but progressively has gotten dimmer as it has gotten older. It is to the point where I can't read it except in the darkest of rooms...and no it is not in dim mode
