05-02-2023
14:28
04:41
05-02-2023
14:28
04:41
This just started happening this week. Usually I can either tap the screen to activate it or flick my wrist to wake it up. But that stopped and I can only see the screen if I push the left side. Did I mess with a setting; or is it dying on me; or something completely different.
05-03-2023 04:52 - edited 05-26-2023 13:00
Hi there, @cafiore. Thanks for stopping by in the Fitbit Community Forums. Thanks for the details provided in your post bout the issue with your Charge 4.
As a first approach, please go to your quick settings and check that screen wake hasn't accidentally been turned off. Press and hold the button, and swipe left to access the quick settings screen. Change whether the screen turns on when you turn your wrist. For more information, see How do I navigate my Fitbit device?
If this settings is set correctly, please try restarting your Charge 4 by following these steps How do I restart my Fitbit device?
If the above doesn't describe your issue and the restart doesn't work, please check if the sleep mode is enabled. When the sleep mode setting is on:
Best Answer05-03-2023 04:52 - edited 05-26-2023 13:00
