04-24-2023
04:59
05:55
04-24-2023
04:59
05:55
Charge 4 blank screen, buzzing, won’t reset
05-03-2023 01:13
05-03-2023 01:13
Fitbit Display Screen Black and Not Working or Turning on?
Charge it Full.
Check if the Fitbit watch is in “water lock mode.”
Remove or Change the Case or Screen Protector.
Clean your Fitbit.
Check the Display Brightness Settings.
Try Restarting.
Change the Clock Face to a Standard Face.
Reset Fitbit.
Regards,
Will
04-24-2023 06:01
04-24-2023 06:01
Hi there, @LinnieLinnie. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 4.
Have you tried charging your Charge 4? If you're having charging issues, please see Why isn't my Fitbit device's battery charging?
Best Answer04-24-2023 06:06
04-24-2023 06:06
Best Answer04-24-2023 07:10
04-24-2023 07:10
@LinnieLinnie Please try restarting your Charge 4 and then, please follow the tips and recommendations I've shared with you here.
Best Answer04-24-2023 14:20
04-24-2023 14:20
Same. It still syncs correctly -
04-25-2023 05:47 - edited 06-07-2023 08:30
Hi there, @gemgimgim. Thanks for stopping by in the Fitbit Community Forums.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Best Answer05-03-2023 01:13
05-03-2023 01:13
Charge it Full.
Clean your Fitbit.
Try Restarting.
Reset Fitbit.
Regards,
Will
05-03-2023 01:20
05-03-2023 01:20
