03-14-2021
15:18
16:09
03-14-2021
15:18
16:09
During a run if the battery drops below 25% watch stops tracking and screen becomes unresponsive
Moderator edit: format and updated subject for clarity.
03-17-2021 13:34
03-17-2021 13:34
Welcome aboard @Lisaital1. Thank you for letting us know that your Charge 4 stops tracking your exercise with low battery.
I would recommend trying to perform your exercise when it has more than 25% battery in order to get it tracked properly.
Keep on visiting the forums.
Best Answer03-17-2021 13:58
03-17-2021 13:58
Thats not very helpful Andrea! If I start a run and the battery is at 30% by the time I get home the battery is around 25% and stops tracking. Are you suggesting that everytime i go for a run I need a minimum battery percentage for it to work properly? If so, what do you suggest? I didn't have this issue with my previous fitbit. Perhaps fitbit needs to look into this as their are numerous complaints about it.
03-17-2021 14:12
03-17-2021 14:12
Thanks for getting back to us and for your feedback @Lisaital1. There's no a minimum battery percentage for the Charge 4 to work properly.
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on what you share here.
See you around.
Best Answer03-17-2021 14:19
03-17-2021 14:19
@Lisaital1 This Help article recommends an 80% battery charge if you want to use built in GPS. I can see that you are new to the Help forum, but not new to Fitbit. Unless you have experience with an Ionic or a Surge, you need to know that built in GPS is a battery hog. Fortunately, as a Charge 4 user, you have the option to use built in or connected GPS. I use a Versa 3 and I do not have that option.
Laurie | Maryland
03-17-2021 14:33
03-17-2021 14:33
Thanks for the link, however, this is a problem that seems to have started a few months ago. It just seems a bit strange that not only has GPS started to drop out but the screen becomes unresponsive with 25% battery as well which doesn't seem right.
12-01-2021 05:43
12-01-2021 05:43
Hello, did you get any resolution with this? Mine does the same, totally stops working, then when I plug in it still had 10% battery or some such. Infuriating!
Best Answer01-21-2022 01:05
01-21-2022 01:05
Just seen your message. No, unfortunately it was more frustrating to keep asking. I just make sure I have at least 50% battery
Best Answer01-21-2022 06:38
01-21-2022 06:38
