07-16-2022
02:43
14:11
07-16-2022
02:43
14:11
Have a Charge 4 I got for birthday present in autumn 2020, unfortunately one of the strap connectors has broken off so pretty much makes it unusable. It’s out of warranty now I guess, but don’t have a receipt due to being a present, has anyone else had this and is there a way to get repaired? Seems a shame to throw it as it’s really useful, but sort of no good if not worn. An6 help appreciated.
@artsfella , A warm welcome to the Community! Thank you for your message and feedback.
Even if the warranty should be over, please give our team a call or chat with them so that they get a closer look at you case and see your options.
Here you'll find our contact options
This happened to me too! I was searching for a solution because my warranty has expired too, I saw this band on Amazon. Basically it wraps around the Fitbit and it doesn’t snap on, so it was really useful it’s just one thing I don’t like about it. It looks a bit bulky but it still works as efficient so it a really good fix. You can buy it on Amazon for about 20-30$, at least that is how much I bought mine for. I will put the name under this reply, hope this helps!
07-18-2022
13:07
18:03
JuanFitbit
07-18-2022
13:07
18:03
JuanFitbit
you can just search this up on Amazon and it would pop right up! For it to work all you have to do is pop your Fitbit screen right in! And it is much more protective then a normal Fitbit wrist band!
Moderator edit: Advertisement
Best AnswerYeah I'm on my second charge 4
The first one broke out of warranty this one only lasted 6 months and was replaced under warranty. Unfortunately the plastic connection to the watch is pretty crappy! They tell you to wear the watch 24/7 and then it just keeps breaking. Fitbit come on you can do a better job than this.
They took off the name of that band, can you put it in words so we can find it. I need it too, this is my 2nd band to break in same spot. Thanks
Me too. 1st one was under warranty but not since I already used the warranty they wont do anything.
2nd charge 4 & broke in same spot too.
Best AnswerSolution for breaking the watch strap from the watch case. It happened to me twice that the watch strap broke off for no apparent reason. The reason is simple. Due to use, dust and dirt can get between the strap and the watch case after some time, this connection with spring button is apparently very tight, so that the pressure eventually becomes too high, resulting in breakage. My solution for this is to regularly remove the strap and clean both the strap and the watch case with water and a brush and to move the spring button several times so that everything is clean and moves well again. Best Regards W. Lemke
Best AnswerSupCase Unicorn Beetle Pro Watch Bands for Fitbit Charge 3 / Charge 4, Protective Replacement Wristband Case Band(Black)
Just search this up! If you want to know how to use it just look at my other replies 🙂 I did put it before but it got taken down because of advertising. Hope this helps!
Best AnswerOf course! Sorry about that, I didn’t know it would be put as advertising.
