12-03-2022
04:45
06:10
AndreaFitbit
12-03-2022
04:45
06:10
AndreaFitbit
The connecties of the watch strap is broken. I have my charge 4 since september 2021.
i cant weer it now. Can you help me?
12-03-2022 06:44
12-03-2022 06:44
Hi @Biker1702 the warranty is one year in the US and 2 years in some European countries. You'll want to get with support.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
12-03-2022 06:44
12-03-2022 06:44
USA: click
12-30-2022 13:11
12-30-2022 13:11
The strap to watch connector is absolute rubbish, as is the Fitbit "support" ! They are designed to break after a year.
I have purchased two Fitbits both had the same problem. I will not buy another and will obviously advise others not to buy Fitbits either.
Best Answer12-30-2022 13:31
12-30-2022 13:31
@ChiefMick if your Charge 4 still works, why not do as others have done. Go to Amazon and search for "protective cover band" for the band completely encompasses the pebble portion of the Charge 4, so you can still wear it.
Best Answer12-30-2022 15:39
12-30-2022 15:39
THANK yooooo, i have the same problem and superglued it once but hinge still coming apart. Looks like the cover bands hold the electronic part all around. Def going this route, do you have any recommendations which brand ? Very happy to find this, gotta say I am hooked on this fitbit tracker. Love it - bike swim weights r me
Best Answer12-30-2022 15:57
12-30-2022 15:57
12-30-2022 16:49
12-30-2022 16:49
@bikeswimlift you might want to check the reviews on Amazon and pick one that suits you best. They do look to be a bit large, but it seems to do the trick for others.
Best Answer01-09-2023 13:51
01-09-2023 13:51
My solution now is to warranty the whole product through Amazon UK.
The regulations in the UK (not sure about elsewhere) are that the first year warranty is with the shop you purchased from (not the manufacturer), therefore it is up to Amazon to replace/repair the strap, they are unwilling to do this. So there is no other option available other than to return the product for a full refund.
My current Charge 4 was exchanged following the strap breaking on the last one in May 2022.
I expect if I go through Fitbit for a new strap it'll take about 14 days if I'm lucky, but if I return the old one for a refund and just buy a new one I will be back up and going by the weekend.
Fitbit know their straps are of questionable quality and rather than fix it they just fob customers off with a replacement strap, as long as they jump through hoops. Their goal seems to be pass customers off with the bad straps until they reach the point where they are no longer warrantied and they buy either a new watch or start buying straps.
Best Answer01-09-2023 14:09
01-09-2023 14:09
