04-02-2022
17:03
14:39
04-02-2022
17:03
14:39
My charge 4 is not working needs to be charged several times a day. Is there a fox. I was hoping it would last longer.
04-03-2022 19:37
04-03-2022 19:37
@latina4you , Nice to see you here. Thank you for your message.
Quick question: Do you use the GPS on the Charge 4 when you have to charge it several times on a day?
Keep in mind that the GPS usage might consume the battery faster as the normal use of the tracker.
Have you tried this: Can I extend my Fitbit device's battery life?
See you around.
Best Answer04-04-2022 05:51
04-04-2022 05:51
Best Answer04-04-2022 05:52
04-04-2022 05:52
Hello Juan
no I do not use the GPS.
Best Answer04-04-2022 09:15
04-04-2022 09:15
For clarity, are you saying that with gps usage, it would be acceptable to have to charge several
times a day? That has not been my experience. I agree it uses battery more quickly, but I have not experienced that level of battery drain. Sounds like a different issue
04-04-2022 18:26
04-04-2022 18:26
@Skere , Nice to see you around. If you use the GPS, the battery may last up to 10 hours. Depending on the setting, how often the tracker synchronized or if you record different GPS activities and battery status before the first activity, it might come that it would be needed to charge more than once on a day.
@latina4you Thank you for your replies and confirmation. In that case, please give us a call or chat with us. Our team will be glad to have a closer look at this.
Click here to get connected.
See you around.
