11-05-2021
04:37
16:06
11-05-2021
04:37
16:06
Welp, the app seems unable to sync after the Android 12 update on my Pixel 4XL.
Says it is taking a while, then says it can't sync. Funny thing is that it synced in the middle of my sleep when I woke up to pee. Now it can't. Experience tells me that they will tell me to remove connection (usually makes things worse) and reset the Fitbit (which erases data). Y'all are both Google products, could you resolve these things without making users use the nuclear option to recover from update breakage?
11-08-2021 03:40 - edited 11-10-2023 04:52
Hi there, @Cantaffordit. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration.
As a first approach, please make sure that your Pixel 4XL does meets the requirements listed here.
If so, please try to restart your Charge 4, turn off other Bluetooth connections when not in use, and shut down your phone. Then, try syncing your Fitbit device.
If the issue persists, please see Why won't my Fitbit device sync?
Hope that helps.
Hope that helps.
05-16-2022 02:11
05-16-2022 02:11
It will stop syncing again after a while it is not a perminant resolution
05-17-2022 07:00 - edited 11-10-2023 04:48
Hi there, @wiamzi. Thanks for stopping by in the Community Forums. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
