01-01-2022
11:00
15:58
01-01-2022
11:00
15:58
I have resynced and rebooted the Charge 4 but since the clock struck midnight on New Years, the time on the Fitbit has been off by exactly 1 hour. My phone that I sync to has the correct time as does my computer. Any suggestions?
01-01-2022 11:51
01-01-2022 11:51
Hi there, @mecole. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Charge 4.
Note that the time on your Fitbit Charge 4 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Charge 4 is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
Hope that helps.
Best Answer01-01-2022 11:51
01-01-2022 11:51
Hope that helps.
Best Answer01-01-2022 19:11
01-01-2022 19:11
Solved. So I took your advice and looked at the Time Zone setting on the App on my phone. It was set to the correct timezone. So I figured what the heck and just toggled the settings and the Fitbit is now correct.
Thank you for your suggestion.
Best Answer01-03-2022 06:21 - edited 01-08-2024 06:58
@mecole Awesome! I'm glad to hear that the steps recommended above did the trick.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Hope that helps.
