06-24-2018
06:37
20:07
06-24-2018
06:37
20:07
I have been for the past few weeks trying to no avail to sync my charge HR. I tried all the steps recommended, I restarted, I updated, I uninstalled, I unpaired and repaired, tried on a different device (whilst it was uninstalled on my Android phone), tried also force stopping and all of that and nothing.
Last night it *finally managed to sync the steps I had at the time, but anything else was not synced (i.e hear rate, sleep, activity etc).
The very strange thing is, that if I receive a call, the charge hr will notify me. So what could possibly be happening for it to have suddenly stopped doing everything else? This is so frustrating!
Moderator Edit: Updated Subject for Clarity
06-25-2018 18:15
06-25-2018 18:15
Mine HR Did the same thing about six months ago. The way I fixed it was I’d let totally discharge it was totally dead left it off for two days. Then I was able to fully charge it and re-sync it hope this helps
06-25-2018
17:40
11:51
06-25-2018
17:40
11:51
@Katinkatze Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing with Charge HR not syncing properly. Thanks for trying all of those steps in order to sort this out.
Have you tried turning off Bluetooth on your phone for 10 seconds and then turning it back on? This usually helps for syncing.
Also, make sure you are using a compatible mobile device to sync.
Keep me posted! ![]()
Best Answer06-25-2018 18:15
06-25-2018 18:15
06-25-2018 23:26
06-25-2018 23:26
07:27
11:51
06-28-2018
07:27
11:51
@Rockychow2 It's great to see you in the Fitbit Community! Thanks for sharing the steps that helped you to sort this out. I'm sure this will be helpful for a lot of users.
@Katinkatze Thanks for your reply and for trying the steps provided to sort this out.
I went ahead and created a case with customer support in your behalf. Please keep an eye on your email inbox for next steps.
06-28-2018 08:00
06-28-2018 08:00
07-04-2018
08:15
11:51
07-04-2018
08:15
11:51
@Katinkatze Thanks for your reply and for providing those details.
No worries, it is better this way so you don't have to call/write and wait a long time. I'm glad that you are already in contact. You will notice that they will start gathering as much information as they can for them to provide the best solution available for you and that you will be back on track soon. Fingers crossed!
Best Answer07-04-2018 08:33
07-04-2018 08:33
So I discharged it totally and left it for a week without charging. I also unpaired it and uninstalled all apps. Recharged, gave it a reset after recharge, and paired it just as though it was a new set up and it worked! So happy and thanks for all the suggestions 🙂
07-04-2018 12:07
07-04-2018 12:07
I am having a problem syncing my Charge HR. It synced last night but today (I use a laptop) I am getting the message that it can't find the Charge HR. It's kind of discouraging that the recommendation seems to be to let it fully discharge for a few days up to a week and then recharge. Are there any other suggestions? I did turn bluetooth off and back on as suggested.
Thank you!
Best Answer07-04-2018 12:10
07-04-2018 12:10
07-04-2018 13:38
07-04-2018 13:38
07:43
11:51
07-05-2018
07:43
11:51
@Katinkatze Thanks for your reply and for sharing the workarounds that helped you out to get back on track. I'm very glad to read you are now syncing properly!
@ohiobetsy I hope you're doing well! Thanks for reporting the situation you are experiencing with syncing Charge HR.
Have you tried @Katinkatze suggestion about resetting Bluetooth? That could help you out. You can also try the steps on this help article as it has helped other users in the past to sync.
@Rockychow2 Thanks for the help provided on this thread. If you don't wish to receive more emails about this thread please click/tap the gear icon at the top right corner of this thread and select "Unsubscribe".
Best Answer07-06-2018 21:12
07-06-2018 21:12
had this happen to me in june and now again for the last 4 days quite frustrating. ive done everything i am supposed to and nothing is working.
Best Answer07-07-2018 00:37
07-07-2018 00:37
07-07-2018 05:54
07-07-2018 05:54
Best Answer07-07-2018 06:27
07-07-2018 06:27
Best Answer07-07-2018 12:16
07-07-2018 12:16
Letting it die uncharged for a couple of days is what broke mine, Jn 23 was the last sync.
Uninstalled, reinstalled app. reset on charger twice.
Will not sync. Sync scheduled is what I get.
About to throw it in the garbage and buy another.
Best Answer07-07-2018 14:13
07-07-2018 14:13
07-07-2018 15:33
07-07-2018 15:33
I reset it to factory instead.Working so far!
07-09-2018
15:55
11:51
07-09-2018
15:55
11:51
@Rockychow2 Thanks for sharing all of those steps that helped you out to get back on track. I'm sure a lot of users will find this helpful.
@SunsetRunner Welcome to the Fitbit family! Thanks for sharing the workaround that helped you out with this. I will leave the steps for factory reset here so other users can try the same.
@PlumbeLimbsFilm I hope you're doing well! Thanks for reporting the situation you are experiencing with syncing. Also, thanks for trying the steps provided.
Are you still experiencing the same? When was the last time it synced?
Keep me posted!
