12-03-2017 16:40 - last edited on 09-06-2020 20:15 by MatthewFitbit
After I hold the button down, the green light flashes and my screen goes black. When it comes back on, it’s STILL the update bar. It’s been stuck on half for 2 whole days now.
I’be looked under the “why can’t my Fitbit update?” post and it hasn’t helped at all. I can’t even restart my Fitbit.
Seriously upset that I haven’t been able to see my stats.
Help!
12-03-2017 17:37
12-03-2017 17:37
this fixed it for me
uninstall / re-install app
"forget device" on bluetooth
fixed it for me , good luck
12-03-2017 17:28
12-03-2017 17:28
Same here I have tried to remove and reset but still all I get on the Fitbit screen is a half done update line. Not happy
12-03-2017 17:30
12-03-2017 17:30
Same here,
Stuck in update mode since Friday, tried the restart even reset, seems bricked to me
12-03-2017 17:34
12-03-2017 17:34
That is exactly what happened to mine too. Very frustrating. Just now.
12-03-2017 17:34 - edited 12-03-2017 17:36
Following this thread.
Same here. Stuck with a half filled line on my Fitbit. Annoying.
Tried hard reset and nothing.
12-03-2017 17:37
12-03-2017 17:37
12-03-2017 20:50
12-03-2017 20:50
12-03-2017 21:31
12-03-2017 21:31
Thank you! It worked at the first try.
12-03-2017 23:53
12-03-2017 23:53
Worked for me! Thank you! 🙏🏼
12-04-2017 03:03
12-04-2017 03:03
Yes I had this issue lastnight.
Managed to get it back - followed the advice on the forum as I got the error:
"fbbluetootherrordomain error 18"
Went to phone settings > bluetooth and told it to forget the Charge HR. Re-opened the app which re-attempted the firmware update which this time started again. The half stuck bar on the fitbit then finished loading and restarted normally on the new firmware version.
This issue is stupid though, I don't think I will get a new fitbit going forward.
12-04-2017 15:02
12-04-2017 15:02
This also helped me! Thank you!!!!
02-03-2018 12:03
02-03-2018 12:03
Thank you so much for this post. I was online and on the phone with Fitbit support for over an hour and they had me run through their troubleshooting over and over with no result. They didn’t seem to understand why I would be angry when they said let’s start from the beginning again why nothing worked. They also said they would do nothing else except their list of troubleshooting even though it wasn’t the update that bricked my Fitbit. They never said to try uninstalling the app. I did that and it fixed it instantly. I was still on the phone with support when I did this and asked why uninstalling that app was not on their list. She replied they don’t recommend it Bc you could lose your dashboard information. However it was on their list for me to “just go out and buy a new Fitbit”. Seriously.... buy a new Fitbit was their answer to their update bricking mine.
02-07-2018 03:39
02-07-2018 03:39
This worked for me - thanks
05-05-2018 11:12
05-05-2018 11:12
I went through all the forum post. I tried to do the 12 sec restart several times ( alteast 30 ~ 40 times) but it never worked. What worked for me was the following
1. Connected the wireless dongle to laptop
2. Connected the Charge HR to the laptop
3. Installed the windows software for Fitbit
4. Just hold for 3 seconds ( not 10 ~12 seconds)
5. Then used the installed software in the laptop to connected and it worked in the first try.
05-08-2018 08:18
05-08-2018 08:18
Same here. Did you ever get it fixed?
05-08-2018 15:00
05-08-2018 15:00
05-08-2018 17:10
05-08-2018 17:10
Yes. Off course. That’s the reason I shared so everyone can benefit from it.
09-04-2018 20:21
09-04-2018 20:21
After 2 years of being frustrated with this. THIS fixed mine. I had already removed it from my app long ago, however apparently removing it from the iPhone "Bluetooth Device List" while it was showing the Update bar is what done it. It then showed a ( ! ) symbol over the bar, then when I opened the app back up it began to update and finished.
03-26-2019 16:06
03-26-2019 16:06
Thanks so much 😄😄
07-05-2019 05:44
07-05-2019 05:44
I had an old HR that had been sitting on the halfway update screen for over 2 years and no reset process or 20 minute internet videos full of ponderous and slow talking people and filled with erm, yea, erm, yea, ermmmmm, kinda yea, ermmmm, yea helped (frankly a waste of time).
It was not attached to my iPhone via Bluetooth so therefore did not need to be removed from my phones Bluetooth attached devices list as many suggest.
It was also not set up in the FitBit App on my iPhone as the HR has been unused and replaced by a new device 2 years back.
My old HR has simply sat in a draw and I was going to give it away so thought I would try again to fix it. I charged it via plugging it into a MacBook to be confronted, yet again, by the halfway bar of death, so this is what I did to fix it and this took maybe 3 minutes all in.
This worked.
1: Removed the current HR 3 device from the FitBit App on my iPhone leaving only my scales, no wrist devices.
2: Used the App to then search for the broken HR which was plugged into my MacBook via the USB cable to maintain charge, nothing more.
3: The FitBit App found it in 5 seconds and started to update the device, at which point the dreaded bar of death began to move to conclude the new update!!!
4: It said wait, but completed the update in around 30 seconds and when done my old HR was back to working as it should, bar of death banished!
There seems to be so much noise and complexity around this issue but for me the above worked. To be clear resets of the device by the button failed and simply flashed green lights (as video after boring video show) to only bring the half update bar back. Stop wasting your time people or over thinking the process.
Hope the above helps or adds to the process outlined.
