01-06-2020
22:00
19:49
01-06-2020
22:00
19:49
My Charge HR first of all would not charge up from the charger lead. I plugged it into my Mac (OS 10.15.2) and it then charged up but would not sync. Also, the wrong time shows on the display. I restarted it, but this made no difference.
I use an Samsung (Android), not an iPhone. I finally did get it to sync last night, but haven't been able toi get it sync since then.
Best AnswerThanks so much. I was able to make it sync again, but both times it synced, yesterday and today, were right after I reinstalled the app, after having uninstalled it. It is quite annoying.
Best AnswerYesterday, I contacted fitbit. There is a solution. You need to download and install the latest software for your fitbit HR. When you do that, you'll be given the option of removing the old version. Do that and then install the new version. Reboot your MAC and then resynch with fitbit. It took a long time for the resynch - 10 min. But I got all of my missing data. Good Luck
